* | user/exe: Add Device Tree section | Vijay Kumar Banerjee | 2019-08-07 | 3 | -19/+95 |
* | user: Move support sections to top level | Sebastian Huber | 2019-08-06 | 7 | -120/+156 |
| | | | | | This is a preparation step to move the bug reporting procedure from the wiki to the user manual and to add a contributing section. | ||||
* | user/bsps : Fix formatting and typo in arm/beagle | Vijay Kumar Banerjee | 2019-07-27 | 1 | -18/+37 |
* | user/bsps : Add documentation for Beagle | Vijay Kumar Banerjee | 2019-07-20 | 1 | -2/+89 |
* | user: Split the ARM BSPs source into separate files. | Chris Johns | 2019-07-12 | 20 | -382/+458 |
* | user: Add the boot image tool command. | Chris Johns | 2019-06-12 | 2 | -0/+446 |
* | user: Document boot image generation | Sebastian Huber | 2019-05-27 | 1 | -1/+12 |
| | | | | Update #3727. | ||||
* | user: Add basic lpc24xx description | Sebastian Huber | 2019-03-18 | 1 | -3/+72 |
| | | | | | Update #3724. Update #3725. | ||||
* | user/test: Update with the latest test configuration format. | Chris Johns | 2019-03-06 | 1 | -14/+96 |
* | User: Change output block to type none. | Chris Johns | 2019-03-01 | 27 | -117/+119 |
* | user: Remove nit-picky warnings. | Chris Johns | 2019-02-28 | 34 | -313/+541 |
* | Add unicode support for commonly used characters like copyright. | Chris Johns | 2019-02-28 | 1 | -8/+10 |
| | | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | ||||
* | Update User Documentation for Host setup for Linux | Vaibhav Gupta | 2019-02-28 | 2 | -0/+7 |
| | | | | | Mention the requirement of 'pax' package for building BSP if RTEMS is configured with '--enable-tests' option, else build fails. | ||||
* | user: Add a Dynamic Loader section. | Chris Johns | 2019-02-20 | 8 | -3/+881 |
* | user: Fix tense in quick start | Sebastian Huber | 2019-02-19 | 2 | -4/+5 |
* | user: Clarify U-Boot commands | Sebastian Huber | 2019-02-19 | 1 | -4/+12 |
* | user: Remove obsolete content in quick start | Sebastian Huber | 2019-02-18 | 1 | -87/+0 |
* | user: Add "Build Your Application" | Sebastian Huber | 2019-02-18 | 2 | -0/+12 |
* | user: Add "Test a Board Support Package (BSP)" | Sebastian Huber | 2019-02-18 | 3 | -0/+69 |
* | user: Add "Build a Board Support Package (BSP)" | Sebastian Huber | 2019-02-18 | 2 | -0/+147 |
* | user: Add "Bootstrap the RTEMS Sources" | Sebastian Huber | 2019-02-18 | 2 | -0/+56 |
* | user: Add "Install the Tool Suite" section | Sebastian Huber | 2019-02-18 | 3 | -0/+130 |
* | user: Add "Obtain the Sources" section | Sebastian Huber | 2019-02-18 | 2 | -0/+52 |
* | user: Rework Prefixes section | Sebastian Huber | 2019-02-18 | 5 | -41/+41 |
| | | | | | | Rename it to "Choose an Installation Prefix". Update #3675. | ||||
* | user: Fix references to prefixes section | Sebastian Huber | 2019-02-18 | 5 | -9/+7 |
* | user: Rework "Host Computer Setup" section | Sebastian Huber | 2019-02-18 | 2 | -10/+14 |
| | | | | Rename it to "Prepare Your Host Computer". | ||||
* | user: Add product name | Sebastian Huber | 2019-02-18 | 1 | -2/+2 |
* | user: Add basic Intel Cyclone V documentation | Sebastian Huber | 2019-02-18 | 1 | -2/+73 |
* | Use pathto() on the genindex URL to make it relative. | Chris Johns | 2019-02-15 | 1 | -2/+0 |
* | waf: Remove as many sys path hacks as we can. | Chris Johns | 2019-02-13 | 1 | -11/+7 |
| | | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance. | ||||
* | build: Prepend project common path | Sebastian Huber | 2019-02-08 | 2 | -2/+2 |
| | | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library). | ||||
* | user: Add basic event recording documentation | Sebastian Huber | 2019-02-01 | 5 | -4/+64 |
| | | | | Update #3665. | ||||
* | user: Use capital letters for acronyms | Sebastian Huber | 2019-01-24 | 2 | -4/+5 |
| | | | | Fix GCC definition. | ||||
* | user: Spell out third-party | Sebastian Huber | 2019-01-24 | 11 | -21/+21 |
* | user: Stub documentation for griscv BSP | Sebastian Huber | 2019-01-22 | 1 | -0/+6 |
| | | | | Update #3678. | ||||
* | user: Add "Host Computer Setup" to "Quick Start" | Sebastian Huber | 2019-01-14 | 2 | -0/+20 |
* | user: Move "Prefixes" to "Quick Start" | Sebastian Huber | 2019-01-14 | 4 | -42/+57 |
| | | | | | Move "Project Sandboxing" to a separate section of the "Installation" chapter since this is an advance topic which may confuse new users. | ||||
* | user: Rework "Hardware" chapter | Sebastian Huber | 2019-01-14 | 8 | -104/+120 |
| | | | | | | | Rename it to "Target Hardware". Remove BSPs section and reference the BSPs chapter instead. Remove explicit list of architectures and reference the BSPs chapter instead. Fix typos. Elaborate multilib description in the architecture section. | ||||
* | user: Move deployment details to RSB chapter | Sebastian Huber | 2019-01-14 | 3 | -155/+164 |
* | user: Move "Ecosystem" into "Introduction" | Sebastian Huber | 2019-01-14 | 3 | -242/+239 |
* | user: Move "Support" to "Introduction" | Sebastian Huber | 2019-01-14 | 3 | -128/+125 |
| | | | | | New users may find it useful to get this information in the introduction. | ||||
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 1 | -8/+12 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | user: Add RSB content as a chapter | Sebastian Huber | 2019-01-14 | 10 | -15/+2772 |
| | | | | Remove the separate RSB manual. | ||||
* | user: Remove unused file | Sebastian Huber | 2019-01-11 | 1 | -10/+0 |
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 66 | -66/+66 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 42 | -42/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 61 | -62/+81 |
* | user: Add TODO entries for all BSP families | Sebastian Huber | 2019-01-09 | 16 | -6/+370 |
| | | | | Update #3464. | ||||
* | user: Rework overview | Sebastian Huber | 2019-01-09 | 3 | -31/+233 |
| | | | | | | Move "Overview", "Real-time Applicaiton Systems" and "Real-time Executive" chapters as sections into new "Introduction" chapter. Add "Feature" section. | ||||
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
