2018-12-20 | Eliminate UTF-8 characters except superscripted 2 in i2c | Joel Sherrill | 2 | -4/+4 | |
2018-11-16 | users/host/posix.rst: Update Ubuntu instructions based on 18.04.1 LTS | Joel Sherrill | 1 | -3/+13 | |
Closes #3416. | |||||
2018-11-16 | glossary.rst: Fix grammar errors (GCI 2018) | Aneendya | 1 | -2/+2 | |
2018-11-16 | user: add a warning not to use special characters in pathnames | Marçal Comajoan Cara | 1 | -0/+7 | |
Spaces and other specical characters in pathnames break builds of any software packages using GNU make. All of the GNU tools and RTEMS use make and this breaks builds. This is a long standing known issue with GNU make, which can't handle spaces in pathnames: https://savannah.gnu.org/bugs/?712 This work was part of GCI 2018. Probably closes #3450. | |||||
2018-11-09 | Remove m32c architecture port | Sebastian Huber | 1 | -2/+1 | |
Update #3599. | |||||
2018-11-09 | user: spelling and grammar fixes | Marçal Comajoan Cara | 2 | -5/+5 | |
This work was part of GCI 2018. | |||||
2018-11-08 | user: Update architecture list | Sebastian Huber | 1 | -1/+3 | |
2018-11-08 | user: Remove obsolete boostrap -p step | Sebastian Huber | 1 | -44/+2 | |
Update #3254. | |||||
2018-11-03 | user: Add RTEMS executable and test documentation. | Chris Johns | 17 | -47/+1371 | |
2018-11-03 | User: Simplify the top level headings. | Chris Johns | 4 | -10/+26 | |
2018-10-19 | Update the copyright year. | Chris Johns | 1 | -1/+1 | |
2018-10-13 | Move duplicate host configuration information from RSB to Users Guide | Joel Sherrill | 4 | -236/+383 | |
2018-10-13 | Merge duplicative RSB Quick Start into Users Guide | Joel Sherrill | 4 | -18/+240 | |
2018-10-01 | user: Document QorIQ BSP variants | Sebastian Huber | 1 | -0/+3 | |
2018-09-25 | user: Add i.MX 7D MMC/SDCard driver | Sebastian Huber | 1 | -0/+8 | |
Close #3525. | |||||
2018-08-29 | user: Add qoriq BSP section | Sebastian Huber | 1 | -1/+78 | |
Update #2854. | |||||
2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2 | -5/+1 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2018-08-20 | user: Update x86-64 chapter with end-of-GSoC status | Amaan Cheval | 1 | -1/+51 | |
2018-08-02 | user: Add RISC-V BSP section | Sebastian Huber | 1 | -1/+109 | |
Update #3433. | |||||
2018-07-18 | user: Add x86_64 BSP chapter | Amaan Cheval | 1 | -1/+142 | |
2018-06-26 | user: Add BSP chapter for each architecture | Sebastian Huber | 19 | -0/+144 | |
Update #3464. | |||||
2018-06-26 | user: Add ARM BSPs chapter | Sebastian Huber | 3 | -0/+153 | |
Add NXP i.MX section as a BSP example. Update #2854. | |||||
2018-06-18 | Adding Trace Documentation | Vidushi Vashishth | 6 | -0/+996 | |
- Updates #3454 - This commit adds Tracing Framework Chapter in the RTEMS User Manual - It comprises of subchapters on RTEMS Trace Linker, Capture Engine, Trace generation techniques explaining trace generation using Trace Buffering and Printk generators and sample demonstrations. | |||||
2018-03-28 | user: Do not mention "bootstrap -p" | Sebastian Huber | 1 | -2/+1 | |
It is now obsolete and was never necessary for an RTEMS users. Update #3254. | |||||
2017-11-13 | Clean up sphinx warnings. | Chris Johns | 6 | -83/+43 | |
- Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
2017-11-13 | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 17 | -228/+30 | |
- Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | |||||
2017-11-12 | Add indexes to all documents. | Chris Johns | 2 | -2/+5 | |
2017-11-09 | Change RTEMS version to 5 | Sebastian Huber | 9 | -228/+244 | |
Update #3220. | |||||
2017-08-11 | Update copyright notices. | Chris Johns | 3 | -11/+32 | |
2017-06-14 | User Manual: Added rtems-tester in the docs | Tanu Hari Dixit | 2 | -0/+447 | |
Added as part of Tools. Made changes according to Chris' review Also removed the ini format part inline with the new release that is expected. | |||||
2017-06-01 | User: Remove conflict marker. | Chris Johns | 1 | -1/+0 | |
2017-05-31 | User: Remove the stash conflict markers. | Chris Johns | 1 | -4/+0 | |
2017-05-31 | User: Improvements to some of the tools commands. | Chris Johns | 3 | -50/+51 | |
2017-05-24 | User Manual: Update the rtems-bsp-builder command. | Chris Johns | 1 | -420/+282 | |
2017-03-27 | waf: Cleaner formatting to see the importing. | Chris Johns | 1 | -6/+7 | |
2017-03-21 | user: Fix typo. | Chris Johns | 1 | -1/+1 | |
2017-03-21 | user: Minor fixes to rtems-bsp-builder. | Chris Johns | 1 | -3/+3 | |
2017-03-21 | user: Add an example of the rtems-bsp-builder running. | Chris Johns | 1 | -2/+389 | |
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -4/+5 | |
2017-03-15 | user: Add tool commands to the user manual. | Chris Johns | 7 | -23/+612 | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | 1 | -3/+3 | |
2017-01-11 | Remove references to SPARC/SIS BSP. Also clean up old ERC32 references. | Joel Sherrill | 1 | -1/+1 | |
updates #2810. | |||||
2016-12-21 | Update version/revision to 4.11.99 | Sebastian Huber | 1 | -2/+2 | |
2016-11-09 | user: Fix header levels. | Chris Johns | 28 | -65/+88 | |
2016-11-02 | Fix spelling. | Chris Johns | 1 | -1/+1 | |
2016-10-31 | waf: Add an install command. | Chris Johns | 1 | -2/+6 | |
2016-10-30 | waf: Formatting. | Chris Johns | 1 | -2/+2 | |
2016-10-29 | user: Add comments about warnings we cannot remove. | Chris Johns | 2 | -0/+5 | |
2016-10-29 | user: Add comment to move to packages. | Chris Johns | 1 | -0/+3 | |
2016-10-27 | ecosys/index.rst: Fix complixity spelling | Joel Sherrill | 1 | -1/+1 | |
