path: root/user (follow)
* ecosys/index.rst: Fix complixity spellingJoel Sherrill2016-10-271-1/+1
* Fix the table and section numbering in the User,Hardware,Tiers section.Chris Johns2016-07-061-16/+16
* Add a Hardware section.Chris Johns2016-07-069-19/+224
* Update the glossary.Chris Johns2016-07-061-0/+25
* Add the RTEMS Kernel section back in.Chris Johns2016-07-043-0/+435
* Reorganisse the User Manual to make it easier to navigate.Chris Johns2016-07-0419-843/+734
* Set SPDX License Identifier in each source file.Chris Johns2016-05-2028-0/+56
* Move images to a common directory.Amar Takhar2016-05-182-1/+1
* Review changes from Chris Mayfield.Chris Johns2016-05-023-61/+67
* Corrections from Worth Burruss. Many thanks.Chris Johns2016-05-022-8/+7
* Corrections from Worth Burruss. Many thanks.Chris Johns2016-05-029-79/+143
* Fix bad formatting that somehow went into the doco.Chris Johns2016-05-021-47/+47
* Corrections from a review.Chris Johns2016-05-023-87/+97
* Corrections and improvements from Worth Burruss (thanks so much).Chris Johns2016-05-022-7/+38
* Corrections.Chris Johns2016-05-023-39/+65
* Add a basics section to Getting Started. Rearrange the content.Chris Johns2016-05-028-380/+563
* Start adding Getting Started guide's Released Version.Chris Johns2016-05-021-2/+267
* Updates from user reviews.Chris Johns2016-05-022-23/+28
* Split installation into separate files.Chris Johns2016-05-026-632/+646
* User manual, devel install and windows install.Chris Johns2016-05-0217-56/+1612
* Add 'waf linkcheck' to check external references.Amar Takhar2016-05-021-1/+1
* Add PDF generation support use with --pdfAmar Takhar2016-05-022-6/+5
* Add support for spellchecking with a custom dictionary.Amar Takhar2016-05-021-1/+1
| | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar.
* Rework how conf.py is handled.Amar Takhar2016-05-022-9/+9
| | | | Needed to switch due to increasing complexity.
* Initial reST documentation using Sphinx.Amar Takhar2016-05-0225-0/+432
