2016-11-09 | user: Fix header levels. | Chris Johns | 28 | -65/+88 | |
2016-11-02 | Fix spelling. | Chris Johns | 1 | -1/+1 | |
2016-10-31 | waf: Add an install command. | Chris Johns | 1 | -2/+6 | |
2016-10-30 | waf: Formatting. | Chris Johns | 1 | -2/+2 | |
2016-10-29 | user: Add comments about warnings we cannot remove. | Chris Johns | 2 | -0/+5 | |
2016-10-29 | user: Add comment to move to packages. | Chris Johns | 1 | -0/+3 | |
2016-10-27 | ecosys/index.rst: Fix complixity spelling | Joel Sherrill | 1 | -1/+1 | |
2016-07-06 | Fix the table and section numbering in the User,Hardware,Tiers section. | Chris Johns | 1 | -16/+16 | |
2016-07-06 | Add a Hardware section. | Chris Johns | 9 | -19/+224 | |
2016-07-06 | Update the glossary. | Chris Johns | 1 | -0/+25 | |
2016-07-04 | Add the RTEMS Kernel section back in. | Chris Johns | 3 | -0/+435 | |
2016-07-04 | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 19 | -843/+734 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 28 | -0/+56 | |
2016-05-18 | Move images to a common directory. | Amar Takhar | 2 | -1/+1 | |
2016-05-02 | Review changes from Chris Mayfield. | Chris Johns | 3 | -61/+67 | |
2016-05-02 | Corrections from Worth Burruss. Many thanks. | Chris Johns | 2 | -8/+7 | |
2016-05-02 | Corrections from Worth Burruss. Many thanks. | Chris Johns | 9 | -79/+143 | |
2016-05-02 | Fix bad formatting that somehow went into the doco. | Chris Johns | 1 | -47/+47 | |
2016-05-02 | Corrections from a review. | Chris Johns | 3 | -87/+97 | |
2016-05-02 | Corrections and improvements from Worth Burruss (thanks so much). | Chris Johns | 2 | -7/+38 | |
2016-05-02 | Corrections. | Chris Johns | 3 | -39/+65 | |
2016-05-02 | Add a basics section to Getting Started. Rearrange the content. | Chris Johns | 8 | -380/+563 | |
2016-05-02 | Start adding Getting Started guide's Released Version. | Chris Johns | 1 | -2/+267 | |
2016-05-02 | Updates from user reviews. | Chris Johns | 2 | -23/+28 | |
2016-05-02 | Split installation into separate files. | Chris Johns | 6 | -632/+646 | |
2016-05-02 | User manual, devel install and windows install. | Chris Johns | 17 | -56/+1612 | |
2016-05-02 | Add 'waf linkcheck' to check external references. | Amar Takhar | 1 | -1/+1 | |
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 2 | -6/+5 | |
2016-05-02 | Add support for spellchecking with a custom dictionary. | Amar Takhar | 1 | -1/+1 | |
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | |||||
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 2 | -9/+9 | |
Needed to switch due to increasing complexity. |
