* | user: Remove RSB sb-builder command | Chris Johns | 2020-08-11 | 2 | -75/+14 |
| | | | | Updates #4045 | ||||
* | user: Add shell environment migration aid | Sebastian Huber | 2020-08-10 | 1 | -0/+27 |
* | user: Mention replacements for removed APIs | Sebastian Huber | 2020-07-15 | 1 | -0/+51 |
* | user: Add v5 to v6 migration help | Sebastian Huber | 2020-07-14 | 2 | -0/+21 |
* | Reflect removal of the epiphany target | Sebastian Huber | 2020-07-05 | 2 | -12/+0 |
| | | | | Update #3941. | ||||
* | user: Document arm/realview-pbx-a9 BSP | Sebastian Huber | 2020-07-02 | 1 | -2/+14 |
* | user/rsb: Update the configuration documentation | Chris Johns | 2020-04-28 | 1 | -39/+13 |
| | | | | Closes #3945 | ||||
* | user/tester: Remove command line help as output | Chris Johns | 2020-04-28 | 1 | -31/+2 |
| | | | | Closes #3381 | ||||
* | user: Update the RSB BSP quick start to say where the tests are installed | Chris Johns | 2020-04-28 | 1 | -1/+3 |
| | | | | Closes #3956 | ||||
* | freebsd: Update to reflect the current release 12 requirements | Chris Johns | 2020-04-27 | 1 | -13/+14 |
| | | | | Closes #3960 | ||||
* | user/imx: Add i.MX6UL/ULL. | Christian Mauderer | 2020-04-15 | 1 | -3/+44 |
| | | | | Update #3869 | ||||
* | user: Update migration guide | Sebastian Huber | 2020-04-15 | 1 | -12/+44 |
| | | | | Update #3895. | ||||
* | user: Fix start app chmod execute of waf. | Chris Johns | 2020-04-14 | 1 | -1/+1 |
* | user: Document event recording | Sebastian Huber | 2020-04-11 | 1 | -10/+212 |
| | | | | Close #3904. | ||||
* | user/tools/tester.rst: Removes text references to 'erc32-run' and replaces ↵ | Cláudio Maia | 2020-04-09 | 1 | -5/+3 |
| | | | | the example with 'erc32-sis' | ||||
* | user/tools/tester.rst: Removes example using 'sparc-rtems5-run' | Cláudio Maia | 2020-04-09 | 1 | -13/+1 |
* | user/tools/tester.rst: Clarifies the need of --rtems-tools in rtems-test ↵ | Cláudio Maia | 2020-04-09 | 1 | -6/+8 |
| | | | | command line | ||||
* | user/tools/tester.rst: Removes wrong reference to GDB | Cláudio Maia | 2020-04-09 | 1 | -3/+0 |
* | user/tools/tester.rst: Cleans up text | Cláudio Maia | 2020-04-09 | 1 | -80/+90 |
* | rsb/configuration: add my copyright | Gedare Bloom | 2020-04-05 | 1 | -0/+1 |
* | user/rsb: describe how to create configuration reports | Gedare Bloom | 2020-04-05 | 1 | -3/+18 |
| | | | | Closes #3629. | ||||
* | rsb: replace asciidoc with rst formatting | Gedare Bloom | 2020-04-05 | 2 | -10/+10 |
* | user/rsb/configuration: fix typo xy to xz | Gedare Bloom | 2020-04-05 | 1 | -2/+2 |
* | rsb/configuration: fix broken link to _configdir | Gedare Bloom | 2020-04-05 | 1 | -2/+3 |
* | user: update copyright and minor typo | Gedare Bloom | 2020-04-04 | 2 | -2/+3 |
* | Chapter-on-need-for-RTEMS-specific-cross-compiler | Utkarsh Rai | 2020-04-04 | 1 | -0/+33 |
| | | | | Removed '-' character and provided definition list format | ||||
* | Update top-level copyrights | Gedare Bloom | 2020-04-03 | 1 | -1/+2 |
* | doc: Moving M68K BSP Content to User Manual (#3905) | Mritunjay | 2020-04-03 | 1 | -2/+188 |
| | | | | Fixed trailing spaces. | ||||
* | user/start/gsoc: fix unicode error and grammar typo | Gedare Bloom | 2020-04-02 | 1 | -2/+2 |
* | start/index: relocate gsoc section | Gedare Bloom | 2020-04-02 | 1 | -1/+1 |
* | start/gsoc: GSoC Getting started instructions. | G S Niteesh Babu | 2020-04-02 | 3 | -0/+134 |
| | | | | | Added instructions to setup development environment for students interested in GSoC. | ||||
* | user/bsp-build: Fix broken cross references. | G S Niteesh Babu | 2020-04-02 | 1 | -2/+2 |
| | | | | | | The QuickStartBSPBuild_Manual and QuickStartBSPBuild_RSB are missing the underscore in front. This breaks any reference to them from other sections. | ||||
* | start/user: describe version numbers and releases | Gedare Bloom | 2020-04-02 | 1 | -0/+49 |
| | | | | Closes #2562. | ||||
* | user/rsb: Fix typos (#3922) | Mritunjay | 2020-04-02 | 4 | -10/+10 |
| | | | | Closes #3922 | ||||
* | user: Use consistent Hello World spelling | Sebastian Huber | 2020-03-30 | 4 | -5/+5 |
* | user: Provide a user friendly configuration | Sebastian Huber | 2020-03-30 | 1 | -4/+4 |
* | gdbarmsim: Remove all references to this deleted BSP family | Joel Sherrill | 2020-03-20 | 3 | -10/+0 |
| | | | | Updates #3611. | ||||
* | user/hosts/posix.rst: Add CentOS 8 information | Joel Sherrill | 2020-03-20 | 1 | -2/+18 |
* | user/raspberrypi: Fix typo | G S Niteesh Babu | 2020-03-19 | 1 | -1/+1 |
| | | | | enable-uart should be enable_uart in config.txt | ||||
* | user: Add a migration chapter | Chris Johns | 2020-03-13 | 3 | -0/+115 |
| | | | | | | | This is a start with the hope we collect useful pieces to aid porting. Please add to this. Closes #3895 | ||||
* | user: Update Quick Start Guide reference. | Chris Johns | 2020-03-13 | 1 | -1/+1 |
* | user: Add anchors to some BSPs. | Chris Johns | 2020-03-13 | 2 | -0/+15 |
* | user: Update Quick Start Guide | Chris Johns | 2020-03-13 | 12 | -210/+821 |
| | | | | | | | | | - Add support for release source archives - Add building the BSP using the RSB - Add building packages using the RSB - Add an application Closes #2998 | ||||
* | user/tools: Add RTEMS TFTP Proxy command documentation | Chris Johns | 2020-02-18 | 4 | -1/+170 |
* | doc/raspberrypi: Added instructions for raspberrypi | G S Niteesh | 2020-02-15 | 1 | -1/+110 |
| | | | | Added instructions to run examples on raspberrypi. | ||||
* | user/testing: Add coverage analysis instructions | Vijay Kumar Banerjee | 2020-02-10 | 2 | -0/+69 |
* | Updated docs to use the standalone SIS simulator, instead of GDB inbuilt SIS ↵ | G S Niteesh | 2020-01-07 | 2 | -16/+132 |
| | | | | for the erc32 BSP. | ||||
* | bsp/xen: Add information on Xen/ARM BSP | Jeff Kubascik | 2019-12-20 | 2 | -0/+80 |
| | | | | Add a README for the new xen bsp. | ||||
* | user: Mention xilinx-zynqmp BSP | Sebastian Huber | 2019-12-19 | 2 | -0/+9 |
| | | | | Close #3682. | ||||
* | user/hosts/posix.rst: Update Ubuntu instructions. | Joel Sherrill | 2019-12-12 | 1 | -2/+3 |
| | | | | | | | | | | Note that the ticket has instructions for what to do if the error message "Error :: You must put some 'source' URIs in your sources.list" is reported. As this occurred on an Ubuntu version that was not LTS, it is not being added. If this error occurs in the future on a LTS release, then add this information. closes #3416. |
