2023-12-20 | user: Automatic version number fixes | Chris Johns | 2 | -16/+16 | |
Updates #4695 | |||||
2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-12-02 | Document CONFIGURE_RECORD_INTERRUPTS_ENABLED | Sebastian Huber | 1 | -60/+5 | |
Close #4769. | |||||
2022-11-08 | Update build system related sections for RTEMS 6 | Sebastian Huber | 1 | -2/+2 | |
Update sections which contained the word "bsp_specs". | |||||
2021-01-04 | user: Mention use of LLVM | Sebastian Huber | 1 | -0/+4 | |
2020-04-11 | user: Document event recording | Sebastian Huber | 1 | -10/+212 | |
Close #3904. | |||||
2019-03-01 | User: Change output block to type none. | Chris Johns | 3 | -10/+10 | |
2019-02-28 | user: Remove nit-picky warnings. | Chris Johns | 4 | -13/+13 | |
2019-02-01 | user: Add basic event recording documentation | Sebastian Huber | 5 | -4/+64 | |
Update #3665. | |||||
2019-01-24 | user: Spell out third-party | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 5 | -5/+5 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 5 | -5/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 5 | -5/+5 | |
2018-12-20 | Eliminate UTF-8 characters except superscripted 2 in i2c | Joel Sherrill | 2 | -4/+4 | |
2018-11-03 | User: Simplify the top level headings. | Chris Johns | 1 | -2/+2 | |
2018-06-18 | Adding Trace Documentation | Vidushi Vashishth | 5 | -0/+994 | |
- Updates #3454 - This commit adds Tracing Framework Chapter in the RTEMS User Manual - It comprises of subchapters on RTEMS Trace Linker, Capture Engine, Trace generation techniques explaining trace generation using Trace Buffering and Printk generators and sample demonstrations. |
