* | user: Use consistent Hello World spelling | Sebastian Huber | 2020-03-30 | 2 | -2/+2 |
* | user/tools: Add RTEMS TFTP Proxy command documentation | Chris Johns | 2020-02-18 | 3 | -1/+168 |
* | Updated docs to use the standalone SIS simulator, instead of GDB inbuilt SIS ↵ | G S Niteesh | 2020-01-07 | 1 | -14/+130 |
| | | | | for the erc32 BSP. | ||||
* | Update docs for log mode change and JSON reporting | Kinsey Moore | 2019-08-22 | 1 | -8/+21 |
| | | | | | | The option --report-mode has been changed to --log-mode to reduce ambiguity and --report-format has been added along with --report-path for machine readable test reporting. | ||||
* | user: Add the boot image tool command. | Chris Johns | 2019-06-12 | 2 | -0/+446 |
* | User: Change output block to type none. | Chris Johns | 2019-03-01 | 4 | -15/+15 |
* | Update User Documentation for Host setup for Linux | Vaibhav Gupta | 2019-02-28 | 1 | -0/+2 |
| | | | | | Mention the requirement of 'pax' package for building BSP if RTEMS is configured with '--enable-tests' option, else build fails. | ||||
* | user: Add a Dynamic Loader section. | Chris Johns | 2019-02-20 | 3 | -0/+6 |
* | user: Rework Prefixes section | Sebastian Huber | 2019-02-18 | 1 | -0/+2 |
| | | | | | | Rename it to "Choose an Installation Prefix". Update #3675. | ||||
* | user: Spell out third-party | Sebastian Huber | 2019-01-24 | 1 | -1/+1 |
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 6 | -6/+6 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 6 | -6/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 6 | -6/+6 |
* | user: Add RTEMS executable and test documentation. | Chris Johns | 2018-11-03 | 1 | -2/+2 |
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 3 | -46/+38 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 2017-11-13 | 1 | -6/+8 |
| | | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | ||||
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 4 | -114/+118 |
| | | | | Update #3220. | ||||
* | User Manual: Added rtems-tester in the docs | Tanu Hari Dixit | 2017-06-14 | 2 | -0/+447 |
| | | | | | | | Added as part of Tools. Made changes according to Chris' review Also removed the ini format part inline with the new release that is expected. | ||||
* | User: Remove conflict marker. | Chris Johns | 2017-06-01 | 1 | -1/+0 |
* | User: Remove the stash conflict markers. | Chris Johns | 2017-05-31 | 1 | -4/+0 |
* | User: Improvements to some of the tools commands. | Chris Johns | 2017-05-31 | 3 | -50/+51 |
* | User Manual: Update the rtems-bsp-builder command. | Chris Johns | 2017-05-24 | 1 | -420/+282 |
* | user: Fix typo. | Chris Johns | 2017-03-21 | 1 | -1/+1 |
* | user: Minor fixes to rtems-bsp-builder. | Chris Johns | 2017-03-21 | 1 | -3/+3 |
* | user: Add an example of the rtems-bsp-builder running. | Chris Johns | 2017-03-21 | 1 | -2/+389 |
* | user: Add tool commands to the user manual. | Chris Johns | 2017-03-15 | 6 | -23/+610 |
* | user: Fix header levels. | Chris Johns | 2016-11-09 | 2 | -3/+1 |
* | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 2016-07-04 | 1 | -8/+8 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 3 | -0/+6 |
* | User manual, devel install and windows install. | Chris Johns | 2016-05-02 | 2 | -5/+0 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 3 | -0/+42 |
