2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 6 | -6/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 6 | -6/+6 | |
2018-11-03 | user: Add RTEMS executable and test documentation. | Chris Johns | 1 | -2/+2 | |
2017-11-13 | Clean up sphinx warnings. | Chris Johns | 3 | -46/+38 | |
- Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
2017-11-13 | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 1 | -6/+8 | |
- Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | |||||
2017-11-09 | Change RTEMS version to 5 | Sebastian Huber | 4 | -114/+118 | |
Update #3220. | |||||
2017-06-14 | User Manual: Added rtems-tester in the docs | Tanu Hari Dixit | 2 | -0/+447 | |
Added as part of Tools. Made changes according to Chris' review Also removed the ini format part inline with the new release that is expected. | |||||
2017-06-01 | User: Remove conflict marker. | Chris Johns | 1 | -1/+0 | |
2017-05-31 | User: Remove the stash conflict markers. | Chris Johns | 1 | -4/+0 | |
2017-05-31 | User: Improvements to some of the tools commands. | Chris Johns | 3 | -50/+51 | |
2017-05-24 | User Manual: Update the rtems-bsp-builder command. | Chris Johns | 1 | -420/+282 | |
2017-03-21 | user: Fix typo. | Chris Johns | 1 | -1/+1 | |
2017-03-21 | user: Minor fixes to rtems-bsp-builder. | Chris Johns | 1 | -3/+3 | |
2017-03-21 | user: Add an example of the rtems-bsp-builder running. | Chris Johns | 1 | -2/+389 | |
2017-03-15 | user: Add tool commands to the user manual. | Chris Johns | 6 | -23/+610 | |
2016-11-09 | user: Fix header levels. | Chris Johns | 2 | -3/+1 | |
2016-07-04 | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 1 | -8/+8 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 3 | -0/+6 | |
2016-05-02 | User manual, devel install and windows install. | Chris Johns | 2 | -5/+0 | |
