* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | user: Add RTEMS executable and test documentation. | Chris Johns | 2018-11-03 | 1 | -2/+2 |
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -32/+38 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 1 | -11/+11 |
| | | | | Update #3220. | ||||
* | User Manual: Added rtems-tester in the docs | Tanu Hari Dixit | 2017-06-14 | 1 | -0/+446 |
Added as part of Tools. Made changes according to Chris' review Also removed the ini format part inline with the new release that is expected. |
