2023-07-18 | user/bsp-build: Fix typo in BSP set builder command | Zainab Olalekan | 1 | -1/+1 | |
changed bsp to arch/bsp | |||||
2023-05-20 | Update company name | Sebastian Huber | 6 | -6/+6 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2023-04-14 | bsp-howto: Fix grammar and improve coherence. | Utkarsh Verma | 2 | -13/+6 | |
2022-08-03 | versions: Update user manual | Chris Johns | 2 | -97/+98 | |
Updates #4695 | |||||
2021-06-15 | user: Fixed typo to build hello application | Ida Delphine | 1 | -1/+1 | |
2021-03-25 | start: provide more version guidance for gsoc | Gedare Bloom | 2 | -2/+6 | |
2021-03-25 | start: Console output example updates | Ida Delphine | 5 | -150/+159 | |
2021-03-25 | app: Update command to configure app | Ida Delphine | 1 | -4/+4 | |
2021-03-25 | bsp-build: Update manual bsp build command | Ida Delphine | 1 | -5/+5 | |
2021-03-25 | tools: Update command to install toolsuite | Ida Delphine | 1 | -5/+5 | |
2021-03-25 | sourses: Update source download command | Ida Delphine | 1 | -2/+2 | |
2021-03-25 | prefixes: Update installation prefix | Ida Delphine | 1 | -4/+4 | |
2021-02-03 | user: remove old build system cmd | G S Niteesh Babu | 1 | -2/+2 | |
2021-02-01 | user: add guidance on version numbers to GSoC guide. | Gedare Bloom | 1 | -0/+6 | |
2020-10-06 | user: Fix RTEMS release URLs | Sebastian Huber | 1 | -6/+6 | |
2020-09-13 | user: Document BSP new build system | Sebastian Huber | 5 | -154/+81 | |
Update #3818. | |||||
2020-09-01 | user: Change the BSP build set path | Chris Johns | 1 | -4/+4 | |
Updates #4048 | |||||
2020-04-28 | user: Update the RSB BSP quick start to say where the tests are installed | Chris Johns | 1 | -1/+3 | |
Closes #3956 | |||||
2020-04-14 | user: Fix start app chmod execute of waf. | Chris Johns | 1 | -1/+1 | |
2020-04-04 | user: update copyright and minor typo | Gedare Bloom | 1 | -2/+2 | |
2020-04-04 | Chapter-on-need-for-RTEMS-specific-cross-compiler | Utkarsh Rai | 1 | -0/+33 | |
Removed '-' character and provided definition list format | |||||
2020-04-02 | user/start/gsoc: fix unicode error and grammar typo | Gedare Bloom | 1 | -2/+2 | |
2020-04-02 | start/index: relocate gsoc section | Gedare Bloom | 1 | -1/+1 | |
2020-04-02 | start/gsoc: GSoC Getting started instructions. | G S Niteesh Babu | 2 | -0/+133 | |
Added instructions to setup development environment for students interested in GSoC. | |||||
2020-04-02 | user/bsp-build: Fix broken cross references. | G S Niteesh Babu | 1 | -2/+2 | |
The QuickStartBSPBuild_Manual and QuickStartBSPBuild_RSB are missing the underscore in front. This breaks any reference to them from other sections. | |||||
2020-04-02 | start/user: describe version numbers and releases | Gedare Bloom | 1 | -0/+49 | |
Closes #2562. | |||||
2020-03-30 | user: Use consistent Hello World spelling | Sebastian Huber | 1 | -2/+2 | |
2020-03-30 | user: Provide a user friendly configuration | Sebastian Huber | 1 | -4/+4 | |
2020-03-13 | user: Update Quick Start Guide | Chris Johns | 11 | -209/+820 | |
- Add support for release source archives - Add building the BSP using the RSB - Add building packages using the RSB - Add an application Closes #2998 | |||||
2020-01-07 | Updated docs to use the standalone SIS simulator, instead of GDB inbuilt SIS ↵ | G S Niteesh | 1 | -2/+2 | |
for the erc32 BSP. | |||||
2019-10-13 | user/rsb: Update 3rd party package build and add packaging details. | Chris Johns | 1 | -8/+15 | |
2019-02-28 | user: Remove nit-picky warnings. | Chris Johns | 1 | -2/+0 | |
2019-02-19 | user: Fix tense in quick start | Sebastian Huber | 2 | -4/+5 | |
2019-02-18 | user: Remove obsolete content in quick start | Sebastian Huber | 1 | -87/+0 | |
2019-02-18 | user: Add "Build Your Application" | Sebastian Huber | 2 | -0/+12 | |
2019-02-18 | user: Add "Test a Board Support Package (BSP)" | Sebastian Huber | 2 | -0/+67 | |
2019-02-18 | user: Add "Build a Board Support Package (BSP)" | Sebastian Huber | 2 | -0/+147 | |
2019-02-18 | user: Add "Bootstrap the RTEMS Sources" | Sebastian Huber | 2 | -0/+56 | |
2019-02-18 | user: Add "Install the Tool Suite" section | Sebastian Huber | 2 | -0/+127 | |
2019-02-18 | user: Add "Obtain the Sources" section | Sebastian Huber | 2 | -0/+52 | |
2019-02-18 | user: Rework Prefixes section | Sebastian Huber | 2 | -39/+37 | |
Rename it to "Choose an Installation Prefix". Update #3675. | |||||
2019-02-18 | user: Fix references to prefixes section | Sebastian Huber | 1 | -2/+3 | |
2019-02-18 | user: Rework "Host Computer Setup" section | Sebastian Huber | 1 | -10/+12 | |
Rename it to "Prepare Your Host Computer". | |||||
2019-01-24 | user: Spell out third-party | Sebastian Huber | 1 | -1/+1 | |
2019-01-14 | user: Add "Host Computer Setup" to "Quick Start" | Sebastian Huber | 2 | -0/+20 | |
2019-01-14 | user: Move "Prefixes" to "Quick Start" | Sebastian Huber | 2 | -0/+56 | |
Move "Project Sandboxing" to a separate section of the "Installation" chapter since this is an advance topic which may confuse new users. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -1/+1 | |
2019-01-09 | user: Rework overview | Sebastian Huber | 1 | -0/+2 | |
Move "Overview", "Real-time Applicaiton Systems" and "Real-time Executive" chapters as sections into new "Introduction" chapter. Add "Feature" section. |
