path: root/user/start (follow)
* user: Fixed typo to build hello applicationIda Delphine2021-06-151-1/+1
* start: provide more version guidance for gsocGedare Bloom2021-03-252-2/+6
* start: Console output example updatesIda Delphine2021-03-255-150/+159
* app: Update command to configure appIda Delphine2021-03-251-4/+4
* bsp-build: Update manual bsp build commandIda Delphine2021-03-251-5/+5
* tools: Update command to install toolsuiteIda Delphine2021-03-251-5/+5
* sourses: Update source download commandIda Delphine2021-03-251-2/+2
* prefixes: Update installation prefixIda Delphine2021-03-251-4/+4
* user: remove old build system cmdG S Niteesh Babu2021-02-031-2/+2
* user: add guidance on version numbers to GSoC guide.Gedare Bloom2021-02-011-0/+6
* user: Fix RTEMS release URLsSebastian Huber2020-10-061-6/+6
* user: Document BSP new build systemSebastian Huber2020-09-135-154/+81
| | | | Update #3818.
* user: Change the BSP build set pathChris Johns2020-09-011-4/+4
| | | | Updates #4048
* user: Update the RSB BSP quick start to say where the tests are installedChris Johns2020-04-281-1/+3
| | | | Closes #3956
* user: Fix start app chmod execute of waf.Chris Johns2020-04-141-1/+1
* user: update copyright and minor typoGedare Bloom2020-04-041-2/+2
* Chapter-on-need-for-RTEMS-specific-cross-compilerUtkarsh Rai2020-04-041-0/+33
| | | | Removed '-' character and provided definition list format
* user/start/gsoc: fix unicode error and grammar typoGedare Bloom2020-04-021-2/+2
* start/index: relocate gsoc sectionGedare Bloom2020-04-021-1/+1
* start/gsoc: GSoC Getting started instructions.G S Niteesh Babu2020-04-022-0/+133
| | | | | Added instructions to setup development environment for students interested in GSoC.
* user/bsp-build: Fix broken cross references.G S Niteesh Babu2020-04-021-2/+2
| | | | | | The QuickStartBSPBuild_Manual and QuickStartBSPBuild_RSB are missing the underscore in front. This breaks any reference to them from other sections.
* start/user: describe version numbers and releasesGedare Bloom2020-04-021-0/+49
| | | | Closes #2562.
* user: Use consistent Hello World spellingSebastian Huber2020-03-301-2/+2
* user: Provide a user friendly configurationSebastian Huber2020-03-301-4/+4
* user: Update Quick Start GuideChris Johns2020-03-1311-209/+820
| | | | | | | | | - Add support for release source archives - Add building the BSP using the RSB - Add building packages using the RSB - Add an application Closes #2998
* Updated docs to use the standalone SIS simulator, instead of GDB inbuilt SIS ↵G S Niteesh2020-01-071-2/+2
| | | | for the erc32 BSP.
* user/rsb: Update 3rd party package build and add packaging details.Chris Johns2019-10-131-8/+15
* user: Remove nit-picky warnings.Chris Johns2019-02-281-2/+0
* user: Fix tense in quick startSebastian Huber2019-02-192-4/+5
* user: Remove obsolete content in quick startSebastian Huber2019-02-181-87/+0
* user: Add "Build Your Application"Sebastian Huber2019-02-182-0/+12
* user: Add "Test a Board Support Package (BSP)"Sebastian Huber2019-02-182-0/+67
* user: Add "Build a Board Support Package (BSP)"Sebastian Huber2019-02-182-0/+147
* user: Add "Bootstrap the RTEMS Sources"Sebastian Huber2019-02-182-0/+56
* user: Add "Install the Tool Suite" sectionSebastian Huber2019-02-182-0/+127
* user: Add "Obtain the Sources" sectionSebastian Huber2019-02-182-0/+52
* user: Rework Prefixes sectionSebastian Huber2019-02-182-39/+37
| | | | | | Rename it to "Choose an Installation Prefix". Update #3675.
* user: Fix references to prefixes sectionSebastian Huber2019-02-181-2/+3
* user: Rework "Host Computer Setup" sectionSebastian Huber2019-02-181-10/+12
| | | | Rename it to "Prepare Your Host Computer".
* user: Spell out third-partySebastian Huber2019-01-241-1/+1
* user: Add "Host Computer Setup" to "Quick Start"Sebastian Huber2019-01-142-0/+20
* user: Move "Prefixes" to "Quick Start"Sebastian Huber2019-01-142-0/+56
| | | | | Move "Project Sandboxing" to a separate section of the "Installation" chapter since this is an advance topic which may confuse new users.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-111-1/+0
* Use standard format for copyright linesSebastian Huber2019-01-111-1/+1
* user: Rework overviewSebastian Huber2019-01-091-0/+2
| | | | | | Move "Overview", "Real-time Applicaiton Systems" and "Real-time Executive" chapters as sections into new "Introduction" chapter. Add "Feature" section.
* Merge duplicative RSB Quick Start into Users GuideJoel Sherrill2018-10-131-15/+35
* user: Do not mention "bootstrap -p"Sebastian Huber2018-03-281-2/+1
| | | | | | It is now obsolete and was never necessary for an RTEMS users. Update #3254.
* Clean up sphinx warnings.Chris Johns2017-11-131-2/+4
| | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229.
* Use '.. toctree::' and not '.. include::' in the User Manual.Chris Johns2017-11-133-102/+0
| | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232.
