path: root/user/start (follow)
* user: Remove nit-picky warnings.Chris Johns2019-02-281-2/+0
* user: Fix tense in quick startSebastian Huber2019-02-192-4/+5
* user: Remove obsolete content in quick startSebastian Huber2019-02-181-87/+0
* user: Add "Build Your Application"Sebastian Huber2019-02-182-0/+12
* user: Add "Test a Board Support Package (BSP)"Sebastian Huber2019-02-182-0/+67
* user: Add "Build a Board Support Package (BSP)"Sebastian Huber2019-02-182-0/+147
* user: Add "Bootstrap the RTEMS Sources"Sebastian Huber2019-02-182-0/+56
* user: Add "Install the Tool Suite" sectionSebastian Huber2019-02-182-0/+127
* user: Add "Obtain the Sources" sectionSebastian Huber2019-02-182-0/+52
* user: Rework Prefixes sectionSebastian Huber2019-02-182-39/+37
| | | | | | Rename it to "Choose an Installation Prefix". Update #3675.
* user: Fix references to prefixes sectionSebastian Huber2019-02-181-2/+3
* user: Rework "Host Computer Setup" sectionSebastian Huber2019-02-181-10/+12
| | | | Rename it to "Prepare Your Host Computer".
* user: Spell out third-partySebastian Huber2019-01-241-1/+1
* user: Add "Host Computer Setup" to "Quick Start"Sebastian Huber2019-01-142-0/+20
* user: Move "Prefixes" to "Quick Start"Sebastian Huber2019-01-142-0/+56
| | | | | Move "Project Sandboxing" to a separate section of the "Installation" chapter since this is an advance topic which may confuse new users.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-111-1/+0
* Use standard format for copyright linesSebastian Huber2019-01-111-1/+1
* user: Rework overviewSebastian Huber2019-01-091-0/+2
| | | | | | Move "Overview", "Real-time Applicaiton Systems" and "Real-time Executive" chapters as sections into new "Introduction" chapter. Add "Feature" section.
* Merge duplicative RSB Quick Start into Users GuideJoel Sherrill2018-10-131-15/+35
* user: Do not mention "bootstrap -p"Sebastian Huber2018-03-281-2/+1
| | | | | | It is now obsolete and was never necessary for an RTEMS users. Update #3254.
* Clean up sphinx warnings.Chris Johns2017-11-131-2/+4
| | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229.
* Use '.. toctree::' and not '.. include::' in the User Manual.Chris Johns2017-11-133-102/+0
| | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232.
* Change RTEMS version to 5Sebastian Huber2017-11-092-8/+8
| | | | Update #3220.
* user: Fix header levels.Chris Johns2016-11-091-1/+1
* Reorganisse the User Manual to make it easier to navigate.Chris Johns2016-07-047-2023/+138
* Set SPDX License Identifier in each source file.Chris Johns2016-05-208-0/+16
* Move images to a common directory.Amar Takhar2016-05-182-1/+1
* Review changes from Chris Mayfield.Chris Johns2016-05-022-34/+40
* Corrections from Worth Burruss. Many thanks.Chris Johns2016-05-021-7/+6
* Corrections from Worth Burruss. Many thanks.Chris Johns2016-05-026-49/+56
* Fix bad formatting that somehow went into the doco.Chris Johns2016-05-021-47/+47
* Corrections from a review.Chris Johns2016-05-023-87/+97
* Corrections and improvements from Worth Burruss (thanks so much).Chris Johns2016-05-022-7/+38
* Corrections.Chris Johns2016-05-023-39/+65
* Add a basics section to Getting Started. Rearrange the content.Chris Johns2016-05-027-380/+562
* Start adding Getting Started guide's Released Version.Chris Johns2016-05-021-2/+267
* Updates from user reviews.Chris Johns2016-05-022-23/+28
* Split installation into separate files.Chris Johns2016-05-025-632/+644
* User manual, devel install and windows install.Chris Johns2016-05-026-13/+1465
* Initial reST documentation using Sphinx.Amar Takhar2016-05-024-0/+51
