* | sourses: Update source download command | Ida Delphine | 2021-03-25 | 1 | -2/+2 |
* | prefixes: Update installation prefix | Ida Delphine | 2021-03-25 | 1 | -4/+4 |
* | user: remove old build system cmd | G S Niteesh Babu | 2021-02-03 | 1 | -2/+2 |
* | user: add guidance on version numbers to GSoC guide. | Gedare Bloom | 2021-02-01 | 1 | -0/+6 |
* | user: Fix RTEMS release URLs | Sebastian Huber | 2020-10-06 | 1 | -6/+6 |
* | user: Document BSP new build system | Sebastian Huber | 2020-09-13 | 5 | -154/+81 |
| | | | | Update #3818. | ||||
* | user: Change the BSP build set path | Chris Johns | 2020-09-01 | 1 | -4/+4 |
| | | | | Updates #4048 | ||||
* | user: Update the RSB BSP quick start to say where the tests are installed | Chris Johns | 2020-04-28 | 1 | -1/+3 |
| | | | | Closes #3956 | ||||
* | user: Fix start app chmod execute of waf. | Chris Johns | 2020-04-14 | 1 | -1/+1 |
* | user: update copyright and minor typo | Gedare Bloom | 2020-04-04 | 1 | -2/+2 |
* | Chapter-on-need-for-RTEMS-specific-cross-compiler | Utkarsh Rai | 2020-04-04 | 1 | -0/+33 |
| | | | | Removed '-' character and provided definition list format | ||||
* | user/start/gsoc: fix unicode error and grammar typo | Gedare Bloom | 2020-04-02 | 1 | -2/+2 |
* | start/index: relocate gsoc section | Gedare Bloom | 2020-04-02 | 1 | -1/+1 |
* | start/gsoc: GSoC Getting started instructions. | G S Niteesh Babu | 2020-04-02 | 2 | -0/+133 |
| | | | | | Added instructions to setup development environment for students interested in GSoC. | ||||
* | user/bsp-build: Fix broken cross references. | G S Niteesh Babu | 2020-04-02 | 1 | -2/+2 |
| | | | | | | The QuickStartBSPBuild_Manual and QuickStartBSPBuild_RSB are missing the underscore in front. This breaks any reference to them from other sections. | ||||
* | start/user: describe version numbers and releases | Gedare Bloom | 2020-04-02 | 1 | -0/+49 |
| | | | | Closes #2562. | ||||
* | user: Use consistent Hello World spelling | Sebastian Huber | 2020-03-30 | 1 | -2/+2 |
* | user: Provide a user friendly configuration | Sebastian Huber | 2020-03-30 | 1 | -4/+4 |
* | user: Update Quick Start Guide | Chris Johns | 2020-03-13 | 11 | -209/+820 |
| | | | | | | | | | - Add support for release source archives - Add building the BSP using the RSB - Add building packages using the RSB - Add an application Closes #2998 | ||||
* | Updated docs to use the standalone SIS simulator, instead of GDB inbuilt SIS ↵ | G S Niteesh | 2020-01-07 | 1 | -2/+2 |
| | | | | for the erc32 BSP. | ||||
* | user/rsb: Update 3rd party package build and add packaging details. | Chris Johns | 2019-10-13 | 1 | -8/+15 |
* | user: Remove nit-picky warnings. | Chris Johns | 2019-02-28 | 1 | -2/+0 |
* | user: Fix tense in quick start | Sebastian Huber | 2019-02-19 | 2 | -4/+5 |
* | user: Remove obsolete content in quick start | Sebastian Huber | 2019-02-18 | 1 | -87/+0 |
* | user: Add "Build Your Application" | Sebastian Huber | 2019-02-18 | 2 | -0/+12 |
* | user: Add "Test a Board Support Package (BSP)" | Sebastian Huber | 2019-02-18 | 2 | -0/+67 |
* | user: Add "Build a Board Support Package (BSP)" | Sebastian Huber | 2019-02-18 | 2 | -0/+147 |
* | user: Add "Bootstrap the RTEMS Sources" | Sebastian Huber | 2019-02-18 | 2 | -0/+56 |
* | user: Add "Install the Tool Suite" section | Sebastian Huber | 2019-02-18 | 2 | -0/+127 |
* | user: Add "Obtain the Sources" section | Sebastian Huber | 2019-02-18 | 2 | -0/+52 |
* | user: Rework Prefixes section | Sebastian Huber | 2019-02-18 | 2 | -39/+37 |
| | | | | | | Rename it to "Choose an Installation Prefix". Update #3675. | ||||
* | user: Fix references to prefixes section | Sebastian Huber | 2019-02-18 | 1 | -2/+3 |
* | user: Rework "Host Computer Setup" section | Sebastian Huber | 2019-02-18 | 1 | -10/+12 |
| | | | | Rename it to "Prepare Your Host Computer". | ||||
* | user: Spell out third-party | Sebastian Huber | 2019-01-24 | 1 | -1/+1 |
* | user: Add "Host Computer Setup" to "Quick Start" | Sebastian Huber | 2019-01-14 | 2 | -0/+20 |
* | user: Move "Prefixes" to "Quick Start" | Sebastian Huber | 2019-01-14 | 2 | -0/+56 |
| | | | | | Move "Project Sandboxing" to a separate section of the "Installation" chapter since this is an advance topic which may confuse new users. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | user: Rework overview | Sebastian Huber | 2019-01-09 | 1 | -0/+2 |
| | | | | | | Move "Overview", "Real-time Applicaiton Systems" and "Real-time Executive" chapters as sections into new "Introduction" chapter. Add "Feature" section. | ||||
* | Merge duplicative RSB Quick Start into Users Guide | Joel Sherrill | 2018-10-13 | 1 | -15/+35 |
* | user: Do not mention "bootstrap -p" | Sebastian Huber | 2018-03-28 | 1 | -2/+1 |
| | | | | | | It is now obsolete and was never necessary for an RTEMS users. Update #3254. | ||||
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -2/+4 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 2017-11-13 | 3 | -102/+0 |
| | | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | ||||
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 2 | -8/+8 |
| | | | | Update #3220. | ||||
* | user: Fix header levels. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 2016-07-04 | 7 | -2023/+138 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 8 | -0/+16 |
* | Move images to a common directory. | Amar Takhar | 2016-05-18 | 2 | -1/+1 |
* | Review changes from Chris Mayfield. | Chris Johns | 2016-05-02 | 2 | -34/+40 |
