2018-10-13 | Merge duplicative RSB Quick Start into Users Guide | Joel Sherrill | 1 | -15/+35 | |
2018-03-28 | user: Do not mention "bootstrap -p" | Sebastian Huber | 1 | -2/+1 | |
It is now obsolete and was never necessary for an RTEMS users. Update #3254. | |||||
2017-11-13 | Clean up sphinx warnings. | Chris Johns | 1 | -2/+4 | |
- Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
2017-11-13 | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 3 | -102/+0 | |
- Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | |||||
2017-11-09 | Change RTEMS version to 5 | Sebastian Huber | 2 | -8/+8 | |
Update #3220. | |||||
2016-11-09 | user: Fix header levels. | Chris Johns | 1 | -1/+1 | |
2016-07-04 | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 7 | -2023/+138 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 8 | -0/+16 | |
2016-05-18 | Move images to a common directory. | Amar Takhar | 2 | -1/+1 | |
2016-05-02 | Review changes from Chris Mayfield. | Chris Johns | 2 | -34/+40 | |
2016-05-02 | Corrections from Worth Burruss. Many thanks. | Chris Johns | 1 | -7/+6 | |
2016-05-02 | Corrections from Worth Burruss. Many thanks. | Chris Johns | 6 | -49/+56 | |
2016-05-02 | Fix bad formatting that somehow went into the doco. | Chris Johns | 1 | -47/+47 | |
2016-05-02 | Corrections from a review. | Chris Johns | 3 | -87/+97 | |
2016-05-02 | Corrections and improvements from Worth Burruss (thanks so much). | Chris Johns | 2 | -7/+38 | |
2016-05-02 | Corrections. | Chris Johns | 3 | -39/+65 | |
2016-05-02 | Add a basics section to Getting Started. Rearrange the content. | Chris Johns | 7 | -380/+562 | |
2016-05-02 | Start adding Getting Started guide's Released Version. | Chris Johns | 1 | -2/+267 | |
2016-05-02 | Updates from user reviews. | Chris Johns | 2 | -23/+28 | |
2016-05-02 | Split installation into separate files. | Chris Johns | 5 | -632/+644 | |
2016-05-02 | User manual, devel install and windows install. | Chris Johns | 6 | -13/+1465 | |
