* | start: Console output example updates | Ida Delphine | 2021-03-25 | 1 | -47/+46 |
* | bsp-build: Update manual bsp build command | Ida Delphine | 2021-03-25 | 1 | -5/+5 |
* | user: Document BSP new build system | Sebastian Huber | 2020-09-13 | 1 | -82/+67 |
| | | | | Update #3818. | ||||
* | user: Update the RSB BSP quick start to say where the tests are installed | Chris Johns | 2020-04-28 | 1 | -1/+3 |
| | | | | Closes #3956 | ||||
* | user/bsp-build: Fix broken cross references. | G S Niteesh Babu | 2020-04-02 | 1 | -2/+2 |
| | | | | | | The QuickStartBSPBuild_Manual and QuickStartBSPBuild_RSB are missing the underscore in front. This breaks any reference to them from other sections. | ||||
* | user: Update Quick Start Guide | Chris Johns | 2020-03-13 | 1 | -22/+120 |
| | | | | | | | | | - Add support for release source archives - Add building the BSP using the RSB - Add building packages using the RSB - Add an application Closes #2998 | ||||
* | user: Add "Build a Board Support Package (BSP)" | Sebastian Huber | 2019-02-18 | 1 | -0/+146 |
