2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 5 | -5/+5 | |
2018-11-08 | user: Remove obsolete boostrap -p step | Sebastian Huber | 1 | -44/+2 | |
Update #3254. | |||||
2018-10-13 | Move duplicate host configuration information from RSB to Users Guide | Joel Sherrill | 1 | -1/+71 | |
2018-10-13 | Merge duplicative RSB Quick Start into Users Guide | Joel Sherrill | 1 | -3/+4 | |
2017-11-13 | Clean up sphinx warnings. | Chris Johns | 1 | -1/+1 | |
- Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
2017-11-13 | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 2 | -8/+9 | |
- Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | |||||
2017-11-09 | Change RTEMS version to 5 | Sebastian Huber | 3 | -106/+118 | |
Update #3220. | |||||
2017-01-11 | Remove references to SPARC/SIS BSP. Also clean up old ERC32 references. | Joel Sherrill | 1 | -1/+1 | |
updates #2810. | |||||
2016-11-09 | user: Fix header levels. | Chris Johns | 5 | -14/+14 | |
2016-10-29 | user: Add comments about warnings we cannot remove. | Chris Johns | 2 | -0/+5 | |
2016-10-29 | user: Add comment to move to packages. | Chris Johns | 1 | -0/+3 | |
2016-07-04 | Add the RTEMS Kernel section back in. | Chris Johns | 2 | -0/+434 | |
2016-07-04 | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 4 | -0/+1154 | |
