* | user, eclipse: Remove RSB sb-bootstrap command | Chris Johns | 2020-08-12 | 2 | -6/+6 |
| | | | | Update #4046 | ||||
* | gdbarmsim: Remove all references to this deleted BSP family | Joel Sherrill | 2020-03-20 | 1 | -1/+0 |
| | | | | Updates #3611. | ||||
* | User: Change output block to type none. | Chris Johns | 2019-03-01 | 3 | -39/+39 |
* | user: Remove nit-picky warnings. | Chris Johns | 2019-02-28 | 1 | -5/+2 |
* | user: Add a Dynamic Loader section. | Chris Johns | 2019-02-20 | 1 | -1/+2 |
* | user: Rework Prefixes section | Sebastian Huber | 2019-02-18 | 1 | -1/+1 |
| | | | | | | Rename it to "Choose an Installation Prefix". Update #3675. | ||||
* | user: Fix references to prefixes section | Sebastian Huber | 2019-02-18 | 2 | -5/+2 |
* | user: Spell out third-party | Sebastian Huber | 2019-01-24 | 1 | -1/+1 |
* | user: Move "Prefixes" to "Quick Start" | Sebastian Huber | 2019-01-14 | 2 | -42/+1 |
| | | | | | Move "Project Sandboxing" to a separate section of the "Installation" chapter since this is an advance topic which may confuse new users. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 5 | -5/+5 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 5 | -5/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 5 | -5/+5 |
* | user: Remove obsolete boostrap -p step | Sebastian Huber | 2018-11-08 | 1 | -44/+2 |
| | | | | Update #3254. | ||||
* | Move duplicate host configuration information from RSB to Users Guide | Joel Sherrill | 2018-10-13 | 1 | -1/+71 |
* | Merge duplicative RSB Quick Start into Users Guide | Joel Sherrill | 2018-10-13 | 1 | -3/+4 |
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -1/+1 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 2017-11-13 | 2 | -8/+9 |
| | | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | ||||
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 3 | -106/+118 |
| | | | | Update #3220. | ||||
* | Remove references to SPARC/SIS BSP. Also clean up old ERC32 references. | Joel Sherrill | 2017-01-11 | 1 | -1/+1 |
| | | | | updates #2810. | ||||
* | user: Fix header levels. | Chris Johns | 2016-11-09 | 5 | -14/+14 |
* | user: Add comments about warnings we cannot remove. | Chris Johns | 2016-10-29 | 2 | -0/+5 |
* | user: Add comment to move to packages. | Chris Johns | 2016-10-29 | 1 | -0/+3 |
* | Add the RTEMS Kernel section back in. | Chris Johns | 2016-07-04 | 2 | -0/+434 |
* | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 2016-07-04 | 4 | -0/+1154 |
