index
rtems-docs
4.11
5
master
RTEMS Project documentation.
devel@rtems.org
summary
refs
log
tree
commit
diff
stats
log msg
author
committer
range
path:
root
user
installation
releases.rst
unfollow
Commit message (
Collapse
Author
Lines
2022-08-03
versions: Update user manual
Chris Johns
1
-176
+17
Updates #4695
2019-03-01
User: Change output block to type none.
Chris Johns
1
-6
+6
2019-02-18
user: Fix references to prefixes section
Sebastian Huber
1
-2
+2
2019-01-24
user: Spell out third-party
Sebastian Huber
1
-1
+1
2019-01-11
Simplify SPDX-License-Identifier comment
Sebastian Huber
1
-1
+1
2019-01-11
Remove superfluous "All rights reserved."
Sebastian Huber
1
-1
+0
2019-01-11
Use standard format for copyright lines
Sebastian Huber
1
-1
+1
2018-10-13
Merge duplicative RSB Quick Start into Users Guide
Joel Sherrill
1
-3
+4
2017-11-09
Change RTEMS version to 5
Sebastian Huber
1
-1
+1
Update #3220.
2017-01-11
Remove references to SPARC/SIS BSP. Also clean up old ERC32 references.
Joel Sherrill
1
-1
+1
updates #2810.
2016-11-09
user: Fix header levels.
Chris Johns
1
-2
+2
2016-10-29
user: Add comment to move to packages.
Chris Johns
1
-0
+3
2016-07-04
Reorganisse the User Manual to make it easier to navigate.
Chris Johns
1
-21
+21
2016-05-20
Set SPDX License Identifier in each source file.
Chris Johns
1
-0
+2
2016-05-02
Corrections from Worth Burruss. Many thanks.
Chris Johns
1
-9
+15
2016-05-02
Corrections from a review.
Chris Johns
1
-9
+10
2016-05-02
Corrections.
Chris Johns
1
-2
+3
2016-05-02
Add a basics section to Getting Started. Rearrange the content.
Chris Johns
1
-12
+10
2016-05-02
Start adding Getting Started guide's Released Version.
Chris Johns
1
-2
+267
2016-05-02
Split installation into separate files.
Chris Johns
1
-0
+11
