* | users/host/posix.rst: Update Ubuntu instructions based on 18.04.1 LTS | Joel Sherrill | 2018-11-16 | 1 | -3/+13 |
| | | | | Closes #3416. | ||||
* | user: add a warning not to use special characters in pathnames | Marçal Comajoan Cara | 2018-11-16 | 1 | -0/+7 |
| | | | | | | | | | | | | | | | Spaces and other specical characters in pathnames break builds of any software packages using GNU make. All of the GNU tools and RTEMS use make and this breaks builds. This is a long standing known issue with GNU make, which can't handle spaces in pathnames: https://savannah.gnu.org/bugs/?712 This work was part of GCI 2018. Probably closes #3450. | ||||
* | Move duplicate host configuration information from RSB to Users Guide | Joel Sherrill | 2018-10-13 | 3 | -235/+312 |
* | Merge duplicative RSB Quick Start into Users Guide | Joel Sherrill | 2018-10-13 | 1 | -0/+45 |
* | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 2017-11-13 | 1 | -4/+6 |
| | | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | ||||
* | user: Fix header levels. | Chris Johns | 2016-11-09 | 5 | -11/+11 |
* | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 2016-07-04 | 5 | -0/+517 |
