* | hosts/posix.rst: Fix typo of sudu to sudo | Joel Sherrill | 2019-08-15 | 1 | -1/+1 |
| | | | | Closes #3754. | ||||
* | hosts/windows.rst: Add warning for spaces in PATH | Joel Sherrill | 2019-08-15 | 1 | -0/+16 |
* | User: Change output block to type none. | Chris Johns | 2019-03-01 | 3 | -14/+14 |
* | user: Remove nit-picky warnings. | Chris Johns | 2019-02-28 | 4 | -86/+102 |
* | Update User Documentation for Host setup for Linux | Vaibhav Gupta | 2019-02-28 | 1 | -0/+5 |
| | | | | | Mention the requirement of 'pax' package for building BSP if RTEMS is configured with '--enable-tests' option, else build fails. | ||||
* | user: Rework Prefixes section | Sebastian Huber | 2019-02-18 | 1 | -1/+1 |
| | | | | | | Rename it to "Choose an Installation Prefix". Update #3675. | ||||
* | user: Fix references to prefixes section | Sebastian Huber | 2019-02-18 | 2 | -2/+2 |
* | user: Spell out third-party | Sebastian Huber | 2019-01-24 | 2 | -4/+4 |
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 5 | -5/+5 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 5 | -5/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 5 | -5/+5 |
* | users/host/posix.rst: Update Ubuntu instructions based on 18.04.1 LTS | Joel Sherrill | 2018-11-16 | 1 | -3/+13 |
| | | | | Closes #3416. | ||||
* | user: add a warning not to use special characters in pathnames | Marçal Comajoan Cara | 2018-11-16 | 1 | -0/+7 |
| | | | | | | | | | | | | | | | Spaces and other specical characters in pathnames break builds of any software packages using GNU make. All of the GNU tools and RTEMS use make and this breaks builds. This is a long standing known issue with GNU make, which can't handle spaces in pathnames: https://savannah.gnu.org/bugs/?712 This work was part of GCI 2018. Probably closes #3450. | ||||
* | Move duplicate host configuration information from RSB to Users Guide | Joel Sherrill | 2018-10-13 | 3 | -235/+312 |
* | Merge duplicative RSB Quick Start into Users Guide | Joel Sherrill | 2018-10-13 | 1 | -0/+45 |
* | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 2017-11-13 | 1 | -4/+6 |
| | | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | ||||
* | user: Fix header levels. | Chris Johns | 2016-11-09 | 5 | -11/+11 |
* | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 2016-07-04 | 5 | -0/+517 |
