* | freebsd: Update to reflect the current release 12 requirements | Chris Johns | 2020-04-27 | 1 | -13/+14 |
| | | | | Closes #3960 | ||||
* | user/hosts/posix.rst: Add CentOS 8 information | Joel Sherrill | 2020-03-20 | 1 | -2/+18 |
* | user/hosts/posix.rst: Update Ubuntu instructions. | Joel Sherrill | 2019-12-12 | 1 | -2/+3 |
| | | | | | | | | | | Note that the ticket has instructions for what to do if the error message "Error :: You must put some 'source' URIs in your sources.list" is reported. As this occurred on an Ubuntu version that was not LTS, it is not being added. If this error occurs in the future on a LTS release, then add this information. closes #3416. | ||||
* | FreeBSDL: Add command to improve waf's performance with Python3. | Chris Johns | 2019-09-05 | 1 | -2/+11 |
* | user/hosts/posix.rst: Improve Ubuntu python 2 devel package instructions | Joel Sherrill | 2019-08-15 | 1 | -3/+9 |
* | hosts/posix.rst: Fix typo of sudu to sudo | Joel Sherrill | 2019-08-15 | 1 | -1/+1 |
| | | | | Closes #3754. | ||||
* | User: Change output block to type none. | Chris Johns | 2019-03-01 | 1 | -10/+10 |
* | user: Remove nit-picky warnings. | Chris Johns | 2019-02-28 | 1 | -35/+52 |
* | Update User Documentation for Host setup for Linux | Vaibhav Gupta | 2019-02-28 | 1 | -0/+5 |
| | | | | | Mention the requirement of 'pax' package for building BSP if RTEMS is configured with '--enable-tests' option, else build fails. | ||||
* | user: Rework Prefixes section | Sebastian Huber | 2019-02-18 | 1 | -1/+1 |
| | | | | | | Rename it to "Choose an Installation Prefix". Update #3675. | ||||
* | user: Fix references to prefixes section | Sebastian Huber | 2019-02-18 | 1 | -1/+1 |
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | users/host/posix.rst: Update Ubuntu instructions based on 18.04.1 LTS | Joel Sherrill | 2018-11-16 | 1 | -3/+13 |
| | | | | Closes #3416. | ||||
* | Move duplicate host configuration information from RSB to Users Guide | Joel Sherrill | 2018-10-13 | 1 | -0/+132 |
* | user: Fix header levels. | Chris Johns | 2016-11-09 | 1 | -2/+2 |
* | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 2016-07-04 | 1 | -0/+39 |
