path: root/user/hardware (follow)
* user/hardware/tiers.rst: Merge info from Wiki.Joel Sherrill2019-12-121-5/+28
| | | | | | | | Tiers had a write up on the Wiki which was similar but different. Merged content from the Wiki which allows the Wiki page to be deleted. closes #3831.
* User: Change output block to type none.Chris Johns2019-03-011-2/+2
* user: Add "Install the Tool Suite" sectionSebastian Huber2019-02-181-0/+3
* user: Spell out third-partySebastian Huber2019-01-241-1/+1
* user: Rework "Hardware" chapterSebastian Huber2019-01-144-82/+87
| | | | | | | Rename it to "Target Hardware". Remove BSPs section and reference the BSPs chapter instead. Remove explicit list of architectures and reference the BSPs chapter instead. Fix typos. Elaborate multilib description in the architecture section.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-115-5/+5
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-115-5/+0
* Use standard format for copyright linesSebastian Huber2019-01-115-5/+5
* Remove m32c architecture portSebastian Huber2018-11-091-2/+1
| | | | Update #3599.
* user: Update architecture listSebastian Huber2018-11-081-1/+3
* Use '.. toctree::' and not '.. include::' in the User Manual.Chris Johns2017-11-131-4/+6
| | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232.
* user: Fix header levels.Chris Johns2016-11-095-5/+5
* Fix the table and section numbering in the User,Hardware,Tiers section.Chris Johns2016-07-061-16/+16
* Add a Hardware section.Chris Johns2016-07-066-0/+216
