2019-12-12 | user/hardware/tiers.rst: Merge info from Wiki. | Joel Sherrill | 1 | -5/+28 | |
Tiers had a write up on the Wiki which was similar but different. Merged content from the Wiki which allows the Wiki page to be deleted. closes #3831. | |||||
2019-03-01 | User: Change output block to type none. | Chris Johns | 1 | -2/+2 | |
2019-02-18 | user: Add "Install the Tool Suite" section | Sebastian Huber | 1 | -0/+3 | |
2019-01-24 | user: Spell out third-party | Sebastian Huber | 1 | -1/+1 | |
2019-01-14 | user: Rework "Hardware" chapter | Sebastian Huber | 4 | -82/+87 | |
Rename it to "Target Hardware". Remove BSPs section and reference the BSPs chapter instead. Remove explicit list of architectures and reference the BSPs chapter instead. Fix typos. Elaborate multilib description in the architecture section. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 5 | -5/+5 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 5 | -5/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 5 | -5/+5 | |
2018-11-09 | Remove m32c architecture port | Sebastian Huber | 1 | -2/+1 | |
Update #3599. | |||||
2018-11-08 | user: Update architecture list | Sebastian Huber | 1 | -1/+3 | |
2017-11-13 | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 1 | -4/+6 | |
- Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | |||||
2016-11-09 | user: Fix header levels. | Chris Johns | 5 | -5/+5 | |
2016-07-06 | Fix the table and section numbering in the User,Hardware,Tiers section. | Chris Johns | 1 | -16/+16 | |
2016-07-06 | Add a Hardware section. | Chris Johns | 6 | -0/+216 | |
