path: root/user/hardware/index.rst (follow)
* user: Rework "Hardware" chapterSebastian Huber2019-01-141-6/+3
| | | | | | | Rename it to "Target Hardware". Remove BSPs section and reference the BSPs chapter instead. Remove explicit list of architectures and reference the BSPs chapter instead. Fix typos. Elaborate multilib description in the architecture section.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-111-1/+0
* Use standard format for copyright linesSebastian Huber2019-01-111-1/+1
* Use '.. toctree::' and not '.. include::' in the User Manual.Chris Johns2017-11-131-4/+6
| | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232.
* user: Fix header levels.Chris Johns2016-11-091-1/+1
* Add a Hardware section.Chris Johns2016-07-061-0/+18
