path: root/user/conf.py (follow)
* Update version/revision to 4.11.99Sebastian Huber2016-12-211-2/+2
* Add a Hardware section.Chris Johns2016-07-061-5/+7
* Add the RTEMS Kernel section back in.Chris Johns2016-07-041-0/+1
* Reorganisse the User Manual to make it easier to navigate.Chris Johns2016-07-041-6/+19
* Add a basics section to Getting Started. Rearrange the content.Chris Johns2016-05-021-0/+1
* Split installation into separate files.Chris Johns2016-05-021-0/+2
* User manual, devel install and windows install.Chris Johns2016-05-021-4/+17
* Add PDF generation support use with --pdfAmar Takhar2016-05-021-0/+4
* Rework how conf.py is handled.Amar Takhar2016-05-021-0/+8
Needed to switch due to increasing complexity.
