* | build: Prepend project common path | Sebastian Huber | 2019-02-08 | 1 | -1/+1 |
| | | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library). | ||||
* | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 2017-11-13 | 1 | -31/+0 |
| | | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | ||||
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -4/+5 |
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -2/+2 |
* | Add a Hardware section. | Chris Johns | 2016-07-06 | 1 | -5/+7 |
* | Add the RTEMS Kernel section back in. | Chris Johns | 2016-07-04 | 1 | -0/+1 |
* | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 2016-07-04 | 1 | -6/+19 |
* | Add a basics section to Getting Started. Rearrange the content. | Chris Johns | 2016-05-02 | 1 | -0/+1 |
* | Split installation into separate files. | Chris Johns | 2016-05-02 | 1 | -0/+2 |
* | User manual, devel install and windows install. | Chris Johns | 2016-05-02 | 1 | -4/+17 |
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 1 | -0/+4 |
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 1 | -0/+8 |
Needed to switch due to increasing complexity. |
