* | user/bsps : Add documentation for Beagle | Vijay Kumar Banerjee | 2019-07-20 | 1 | -2/+89 |
* | user: Split the ARM BSPs source into separate files. | Chris Johns | 2019-07-12 | 20 | -382/+458 |
* | user: Document boot image generation | Sebastian Huber | 2019-05-27 | 1 | -1/+12 |
| | | | | Update #3727. | ||||
* | user: Add basic lpc24xx description | Sebastian Huber | 2019-03-18 | 1 | -3/+72 |
| | | | | | Update #3724. Update #3725. | ||||
* | User: Change output block to type none. | Chris Johns | 2019-03-01 | 3 | -8/+8 |
* | user: Remove nit-picky warnings. | Chris Johns | 2019-02-28 | 2 | -10/+10 |
* | user: Clarify U-Boot commands | Sebastian Huber | 2019-02-19 | 1 | -4/+12 |
* | user: Add product name | Sebastian Huber | 2019-02-18 | 1 | -2/+2 |
* | user: Add basic Intel Cyclone V documentation | Sebastian Huber | 2019-02-18 | 1 | -2/+73 |
* | user: Stub documentation for griscv BSP | Sebastian Huber | 2019-01-22 | 1 | -0/+6 |
| | | | | Update #3678. | ||||
* | user: Rework "Hardware" chapter | Sebastian Huber | 2019-01-14 | 1 | -20/+26 |
| | | | | | | | Rename it to "Target Hardware". Remove BSPs section and reference the BSPs chapter instead. Remove explicit list of architectures and reference the BSPs chapter instead. Fix typos. Elaborate multilib description in the architecture section. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 20 | -20/+20 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 20 | -21/+40 |
* | user: Add TODO entries for all BSP families | Sebastian Huber | 2019-01-09 | 16 | -6/+370 |
| | | | | Update #3464. | ||||
* | User: Simplify the top level headings. | Chris Johns | 2018-11-03 | 1 | -3/+11 |
* | user: Document QorIQ BSP variants | Sebastian Huber | 2018-10-01 | 1 | -0/+3 |
* | user: Add i.MX 7D MMC/SDCard driver | Sebastian Huber | 2018-09-25 | 1 | -0/+8 |
| | | | | Close #3525. | ||||
* | user: Add qoriq BSP section | Sebastian Huber | 2018-08-29 | 1 | -1/+78 |
| | | | | Update #2854. | ||||
* | user: Update x86-64 chapter with end-of-GSoC status | Amaan Cheval | 2018-08-20 | 1 | -1/+51 |
* | user: Add RISC-V BSP section | Sebastian Huber | 2018-08-02 | 1 | -1/+109 |
| | | | | Update #3433. | ||||
* | user: Add x86_64 BSP chapter | Amaan Cheval | 2018-07-18 | 1 | -1/+142 |
* | user: Add BSP chapter for each architecture | Sebastian Huber | 2018-06-26 | 19 | -0/+144 |
* | user: Add ARM BSPs chapter | Sebastian Huber | 2018-06-26 | 2 | -0/+152 |
Add NXP i.MX section as a BSP example. Update #2854. |
