* | pc386 BSP: add a note about default baud rate for console over UART/COM. | Karel Gardas | 2020-09-21 | 1 | -0/+4 |
* | user/pc386 BSP: add documentation. | Karel Gardas | 2020-09-09 | 1 | -1/+395 |
| | | | | | The content is compiled from TBR pc386 wiki page, BSP's README files and from the actual BSP code. | ||||
* | user: Add xilinx-zynq BSP details | Chris Johns | 2020-09-08 | 1 | -2/+112 |
* | Reflect removal of the epiphany target | Sebastian Huber | 2020-07-05 | 2 | -12/+0 |
| | | | | Update #3941. | ||||
* | user: Document arm/realview-pbx-a9 BSP | Sebastian Huber | 2020-07-02 | 1 | -2/+14 |
* | user/imx: Add i.MX6UL/ULL. | Christian Mauderer | 2020-04-15 | 1 | -3/+44 |
| | | | | Update #3869 | ||||
* | doc: Moving M68K BSP Content to User Manual (#3905) | Mritunjay | 2020-04-03 | 1 | -2/+188 |
| | | | | Fixed trailing spaces. | ||||
* | gdbarmsim: Remove all references to this deleted BSP family | Joel Sherrill | 2020-03-20 | 2 | -9/+0 |
| | | | | Updates #3611. | ||||
* | user/raspberrypi: Fix typo | G S Niteesh Babu | 2020-03-19 | 1 | -1/+1 |
| | | | | enable-uart should be enable_uart in config.txt | ||||
* | user: Add anchors to some BSPs. | Chris Johns | 2020-03-13 | 2 | -0/+15 |
* | doc/raspberrypi: Added instructions for raspberrypi | G S Niteesh | 2020-02-15 | 1 | -1/+110 |
| | | | | Added instructions to run examples on raspberrypi. | ||||
* | bsp/xen: Add information on Xen/ARM BSP | Jeff Kubascik | 2019-12-20 | 2 | -0/+80 |
| | | | | Add a README for the new xen bsp. | ||||
* | user: Mention xilinx-zynqmp BSP | Sebastian Huber | 2019-12-19 | 2 | -0/+9 |
| | | | | Close #3682. | ||||
* | user: Add frdme310arty BSP varient | Pragnesh Patel | 2019-11-29 | 1 | -0/+8 |
| | | | | | | Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com> Update #3785. | ||||
* | bsps/beagle: update i2c section | Vijay Kumar Banerjee | 2019-09-26 | 1 | -3/+3 |
* | user/exe: Add link reference in device-tree | Vijay Kumar Banerjee | 2019-08-11 | 1 | -1/+1 |
* | user/bsps: Fix typo in beagle | Vijay Kumar Banerjee | 2019-08-08 | 1 | -2/+2 |
* | user/exe: Add Device Tree section | Vijay Kumar Banerjee | 2019-08-07 | 1 | -19/+2 |
* | user/bsps : Fix formatting and typo in arm/beagle | Vijay Kumar Banerjee | 2019-07-27 | 1 | -18/+37 |
* | user/bsps : Add documentation for Beagle | Vijay Kumar Banerjee | 2019-07-20 | 1 | -2/+89 |
* | user: Split the ARM BSPs source into separate files. | Chris Johns | 2019-07-12 | 20 | -382/+458 |
* | user: Document boot image generation | Sebastian Huber | 2019-05-27 | 1 | -1/+12 |
| | | | | Update #3727. | ||||
* | user: Add basic lpc24xx description | Sebastian Huber | 2019-03-18 | 1 | -3/+72 |
| | | | | | Update #3724. Update #3725. | ||||
* | User: Change output block to type none. | Chris Johns | 2019-03-01 | 3 | -8/+8 |
* | user: Remove nit-picky warnings. | Chris Johns | 2019-02-28 | 2 | -10/+10 |
* | user: Clarify U-Boot commands | Sebastian Huber | 2019-02-19 | 1 | -4/+12 |
* | user: Add product name | Sebastian Huber | 2019-02-18 | 1 | -2/+2 |
* | user: Add basic Intel Cyclone V documentation | Sebastian Huber | 2019-02-18 | 1 | -2/+73 |
* | user: Stub documentation for griscv BSP | Sebastian Huber | 2019-01-22 | 1 | -0/+6 |
| | | | | Update #3678. | ||||
* | user: Rework "Hardware" chapter | Sebastian Huber | 2019-01-14 | 1 | -20/+26 |
| | | | | | | | Rename it to "Target Hardware". Remove BSPs section and reference the BSPs chapter instead. Remove explicit list of architectures and reference the BSPs chapter instead. Fix typos. Elaborate multilib description in the architecture section. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 20 | -20/+20 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 20 | -21/+40 |
* | user: Add TODO entries for all BSP families | Sebastian Huber | 2019-01-09 | 16 | -6/+370 |
| | | | | Update #3464. | ||||
* | User: Simplify the top level headings. | Chris Johns | 2018-11-03 | 1 | -3/+11 |
* | user: Document QorIQ BSP variants | Sebastian Huber | 2018-10-01 | 1 | -0/+3 |
* | user: Add i.MX 7D MMC/SDCard driver | Sebastian Huber | 2018-09-25 | 1 | -0/+8 |
| | | | | Close #3525. | ||||
* | user: Add qoriq BSP section | Sebastian Huber | 2018-08-29 | 1 | -1/+78 |
| | | | | Update #2854. | ||||
* | user: Update x86-64 chapter with end-of-GSoC status | Amaan Cheval | 2018-08-20 | 1 | -1/+51 |
* | user: Add RISC-V BSP section | Sebastian Huber | 2018-08-02 | 1 | -1/+109 |
| | | | | Update #3433. | ||||
* | user: Add x86_64 BSP chapter | Amaan Cheval | 2018-07-18 | 1 | -1/+142 |
* | user: Add BSP chapter for each architecture | Sebastian Huber | 2018-06-26 | 19 | -0/+144 |
* | user: Add ARM BSPs chapter | Sebastian Huber | 2018-06-26 | 2 | -0/+152 |
Add NXP i.MX section as a BSP example. Update #2854. |
