2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2020-07-05 | Reflect removal of the epiphany target | Sebastian Huber | 1 | -1/+0 | |
Update #3941. | |||||
2019-03-01 | User: Change output block to type none. | Chris Johns | 1 | -1/+1 | |
2019-01-14 | user: Rework "Hardware" chapter | Sebastian Huber | 1 | -20/+26 | |
Rename it to "Target Hardware". Remove BSPs section and reference the BSPs chapter instead. Remove explicit list of architectures and reference the BSPs chapter instead. Fix typos. Elaborate multilib description in the architecture section. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -1/+1 | |
2018-11-03 | User: Simplify the top level headings. | Chris Johns | 1 | -3/+11 | |
2018-06-26 | user: Add BSP chapter for each architecture | Sebastian Huber | 1 | -0/+18 | |
Update #3464. | |||||
2018-06-26 | user: Add ARM BSPs chapter | Sebastian Huber | 1 | -0/+14 | |
Add NXP i.MX section as a BSP example. Update #2854. |
