path: root/shell (follow)
* Update version/revision to 4.11.99Sebastian Huber2016-12-211-2/+2
* Document CPUINFOSebastian Huber2016-12-191-0/+70
| | | | Close #2723.
* shell: Fix header levels.Chris Johns2016-11-099-15/+11
* shell: Update commands to use descriptions.Chris Johns2016-11-087-4488/+4303
* Remove the old files.Chris Johns2016-10-291-6998/+0
* shell: Fix code-block warnings.Chris Johns2016-10-295-294/+293
* rtems-docs: Fix many unnecessary back slashesJoel Sherrill2016-10-272-11/+11
* Merge branch 'master' of ssh://dispatch.rtems.org/data/git/rtems-docsJoel Sherrill2016-10-271-1/+8
| * shell/file_and_directory.rst: Correct mkdos command.Joel Sherrill2016-10-271-1/+8
* | Misc: Capitalize RTEMS.Joel Sherrill2016-10-272-6/+6
* Set SPDX License Identifier in each source file.Chris Johns2016-05-2011-0/+22
* Update version numbers and the titles.Chris Johns2016-05-021-3/+4
* Update the shell user's guide top level.Chris Johns2016-05-021-10/+14
* Add OAR copyright to each file.Chris Johns2016-05-026-1/+25
* Clean up.Chris Johns2016-05-021-370/+431
* Clean up.Chris Johns2016-05-021-229/+249
* Clean up the memory commands.Chris Johns2016-05-021-162/+186
* Add links from the command list to the commands.Chris Johns2016-05-022-47/+140
* Add 'waf linkcheck' to check external references.Amar Takhar2016-05-021-1/+1
* Add PDF generation support use with --pdfAmar Takhar2016-05-022-6/+5
* Add missed conf.py.Amar Takhar2016-05-021-0/+8
| | | | No idea how this happened.
* Clean up of file and directory commands.Chris Johns2016-05-021-850/+866
* Add support for spellchecking with a custom dictionary.Amar Takhar2016-05-021-1/+1
| | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar.
* Convert all Unicode to ASCII(128)Amar Takhar2016-05-024-47/+47
* Rework how conf.py is handled.Amar Takhar2016-05-021-9/+1
| | | | Needed to switch due to increasing complexity.
* Clean up of general commands.Chris Johns2016-05-021-308/+319
* Move preface/intro one level up so the section is unnumbered.Amar Takhar2016-05-021-1/+2
* Clean up config and init.Chris Johns2016-05-021-26/+25
* Split document.Amar Takhar2016-05-0211-1/+7005
* Clean up the alias command.Chris Johns2016-05-021-34/+33
* Cleaned up to General Commands.Chris Johns2016-05-021-346/+246
* Fix references.Amar Takhar2016-05-021-9/+3
* Fix broken markup.Amar Takhar2016-05-021-1/+44
* Initial reST documentation using Sphinx.Amar Takhar2016-05-023-0/+7080
