2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 2 | -6/+5 | |
2016-05-02 | Add missed conf.py. | Amar Takhar | 1 | -0/+8 | |
No idea how this happened. | |||||
2016-05-02 | Clean up of file and directory commands. | Chris Johns | 1 | -850/+866 | |
2016-05-02 | Add support for spellchecking with a custom dictionary. | Amar Takhar | 1 | -1/+1 | |
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | |||||
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 4 | -47/+47 | |
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 1 | -9/+1 | |
Needed to switch due to increasing complexity. | |||||
2016-05-02 | Clean up of general commands. | Chris Johns | 1 | -308/+319 | |
2016-05-02 | Move preface/intro one level up so the section is unnumbered. | Amar Takhar | 1 | -1/+2 | |
2016-05-02 | Clean up config and init. | Chris Johns | 1 | -26/+25 | |
2016-05-02 | Split document. | Amar Takhar | 11 | -1/+7005 | |
2016-05-02 | Clean up the alias command. | Chris Johns | 1 | -34/+33 | |
2016-05-02 | Cleaned up to General Commands. | Chris Johns | 1 | -346/+246 | |
2016-05-02 | Fix references. | Amar Takhar | 1 | -9/+3 | |
2016-05-02 | Fix broken markup. | Amar Takhar | 1 | -1/+44 | |
