path: root/shell (unfollow)
2018-10-19Update the copyright year.Chris Johns1-1/+1
2018-08-21build: Fix indexing so it works on HTML and PDF.Chris Johns2-5/+1
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
2017-11-12Add indexes to all documents.Chris Johns2-2/+5
Update #3229.
2017-08-11Update copyright notices.Chris Johns1-5/+8
2017-06-16shell: Update task commandSebastian Huber1-3/+3
2017-03-27waf: Cleaner formatting to see the importing.Chris Johns1-2/+7
2017-03-20Use a single top level version number.Chris Johns1-4/+5
2017-02-14shell: Update task commandSebastian Huber1-3/+3
Update #2858.
2017-01-31shell: Update task commandSebastian Huber1-4/+4
Update #2858.
2017-01-13shell: Update cpuuse and stackuse sample outputSebastian Huber1-27/+87
2017-01-11Update document titles for consistencyJoel Sherrill2-7/+7
2016-12-21Update version/revision to 4.11.99Sebastian Huber1-2/+2
2016-12-19Document CPUINFOSebastian Huber1-0/+70
Close #2723.
2016-11-09shell: Fix header levels.Chris Johns9-15/+11
2016-11-08shell: Update commands to use descriptions.Chris Johns7-4488/+4303
2016-10-29Remove the old files.Chris Johns1-6998/+0
2016-10-29shell: Fix code-block warnings.Chris Johns5-294/+293
2016-10-27rtems-docs: Fix many unnecessary back slashesJoel Sherrill2-11/+11
2016-10-27Misc: Capitalize RTEMS.Joel Sherrill2-6/+6
2016-10-27shell/file_and_directory.rst: Correct mkdos command.Joel Sherrill1-1/+8
2016-05-20Set SPDX License Identifier in each source file.Chris Johns11-0/+22
2016-05-02Update version numbers and the titles.Chris Johns1-3/+4
2016-05-02Update the shell user's guide top level.Chris Johns1-10/+14
2016-05-02Add OAR copyright to each file.Chris Johns6-1/+25
2016-05-02Clean up.Chris Johns1-370/+431
2016-05-02Clean up.Chris Johns1-229/+249
2016-05-02Clean up the memory commands.Chris Johns1-162/+186
2016-05-02Add links from the command list to the commands.Chris Johns2-47/+140
2016-05-02Add 'waf linkcheck' to check external references.Amar Takhar1-1/+1
2016-05-02Add PDF generation support use with --pdfAmar Takhar2-6/+5
2016-05-02Add missed conf.py.Amar Takhar1-0/+8
No idea how this happened.
2016-05-02Clean up of file and directory commands.Chris Johns1-850/+866
2016-05-02Add support for spellchecking with a custom dictionary.Amar Takhar1-1/+1
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar.
2016-05-02Convert all Unicode to ASCII(128)Amar Takhar4-47/+47
2016-05-02Rework how conf.py is handled.Amar Takhar1-9/+1
Needed to switch due to increasing complexity.
2016-05-02Clean up of general commands.Chris Johns1-308/+319
2016-05-02Move preface/intro one level up so the section is unnumbered.Amar Takhar1-1/+2
2016-05-02Clean up config and init.Chris Johns1-26/+25
2016-05-02Split document.Amar Takhar11-1/+7005
2016-05-02Clean up the alias command.Chris Johns1-34/+33
2016-05-02Cleaned up to General Commands.Chris Johns1-346/+246
2016-05-02Fix references.Amar Takhar1-9/+3
2016-05-02Fix broken markup.Amar Takhar1-1/+44
