path: root/shell (follow)
* shell: Add CONFIGURE_MAXIMUM_POSIX_KEYS entry.Chris Johns2019-06-111-0/+9
* shell/dl: Add dynamic loader commandsChris Johns2019-03-212-1/+726
* Add unicode support for commonly used characters like copyright.Chris Johns2019-02-281-4/+6
| | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals.
* Use pathto() on the genindex URL to make it relative.Chris Johns2019-02-151-2/+0
* waf: Remove as many sys path hacks as we can.Chris Johns2019-02-131-11/+7
| | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance.
* build: Prepend project common pathSebastian Huber2019-02-082-2/+2
| | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library).
* Reformat and update copyright and license noticesSebastian Huber2019-01-141-8/+8
| | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-1110-10/+10
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-1110-10/+0
* Use standard format for copyright linesSebastian Huber2019-01-1110-20/+10
* Add common header.rst to reduce copy and pasteSebastian Huber2019-01-091-23/+1
* Update the copyright year.Chris Johns2018-10-191-1/+1
* build: Fix indexing so it works on HTML and PDF.Chris Johns2018-08-212-5/+1
| | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
* Add indexes to all documents.Chris Johns2017-11-122-2/+5
| | | | Update #3229.
* Update copyright notices.Chris Johns2017-08-111-5/+8
* shell: Update task commandSebastian Huber2017-06-161-3/+3
* waf: Cleaner formatting to see the importing.Chris Johns2017-03-271-2/+7
* Use a single top level version number.Chris Johns2017-03-201-4/+5
* shell: Update task commandSebastian Huber2017-02-141-3/+3
| | | | Update #2858.
* shell: Update task commandSebastian Huber2017-01-311-4/+4
| | | | Update #2858.
* shell: Update cpuuse and stackuse sample outputSebastian Huber2017-01-131-27/+87
* Update document titles for consistencyJoel Sherrill2017-01-112-7/+7
* Update version/revision to 4.11.99Sebastian Huber2016-12-211-2/+2
* Document CPUINFOSebastian Huber2016-12-191-0/+70
| | | | Close #2723.
* shell: Fix header levels.Chris Johns2016-11-099-15/+11
* shell: Update commands to use descriptions.Chris Johns2016-11-087-4488/+4303
* Remove the old files.Chris Johns2016-10-291-6998/+0
* shell: Fix code-block warnings.Chris Johns2016-10-295-294/+293
* rtems-docs: Fix many unnecessary back slashesJoel Sherrill2016-10-272-11/+11
* Merge branch 'master' of ssh://dispatch.rtems.org/data/git/rtems-docsJoel Sherrill2016-10-271-1/+8
| * shell/file_and_directory.rst: Correct mkdos command.Joel Sherrill2016-10-271-1/+8
* | Misc: Capitalize RTEMS.Joel Sherrill2016-10-272-6/+6
* Set SPDX License Identifier in each source file.Chris Johns2016-05-2011-0/+22
* Update version numbers and the titles.Chris Johns2016-05-021-3/+4
* Update the shell user's guide top level.Chris Johns2016-05-021-10/+14
* Add OAR copyright to each file.Chris Johns2016-05-026-1/+25
* Clean up.Chris Johns2016-05-021-370/+431
* Clean up.Chris Johns2016-05-021-229/+249
* Clean up the memory commands.Chris Johns2016-05-021-162/+186
* Add links from the command list to the commands.Chris Johns2016-05-022-47/+140
* Add 'waf linkcheck' to check external references.Amar Takhar2016-05-021-1/+1
* Add PDF generation support use with --pdfAmar Takhar2016-05-022-6/+5
* Add missed conf.py.Amar Takhar2016-05-021-0/+8
| | | | No idea how this happened.
* Clean up of file and directory commands.Chris Johns2016-05-021-850/+866
* Add support for spellchecking with a custom dictionary.Amar Takhar2016-05-021-1/+1
| | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar.
* Convert all Unicode to ASCII(128)Amar Takhar2016-05-024-47/+47
* Rework how conf.py is handled.Amar Takhar2016-05-021-9/+1
| | | | Needed to switch due to increasing complexity.
* Clean up of general commands.Chris Johns2016-05-021-308/+319
* Move preface/intro one level up so the section is unnumbered.Amar Takhar2016-05-021-1/+2
* Clean up config and init.Chris Johns2016-05-021-26/+25
