2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2 | -5/+1 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2017-11-12 | Add indexes to all documents. | Chris Johns | 2 | -2/+5 | |
Update #3229. | |||||
2017-08-11 | Update copyright notices. | Chris Johns | 1 | -5/+8 | |
2017-06-16 | shell: Update task command | Sebastian Huber | 1 | -3/+3 | |
2017-03-27 | waf: Cleaner formatting to see the importing. | Chris Johns | 1 | -2/+7 | |
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -4/+5 | |
2017-02-14 | shell: Update task command | Sebastian Huber | 1 | -3/+3 | |
Update #2858. | |||||
2017-01-31 | shell: Update task command | Sebastian Huber | 1 | -4/+4 | |
2017-01-13 | shell: Update cpuuse and stackuse sample output | Sebastian Huber | 1 | -27/+87 | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | 2 | -7/+7 | |
2016-12-21 | Update version/revision to 4.11.99 | Sebastian Huber | 1 | -2/+2 | |
2016-12-19 | Document CPUINFO | Sebastian Huber | 1 | -0/+70 | |
Close #2723. | |||||
2016-11-09 | shell: Fix header levels. | Chris Johns | 9 | -15/+11 | |
2016-11-08 | shell: Update commands to use descriptions. | Chris Johns | 7 | -4488/+4303 | |
2016-10-29 | Remove the old files. | Chris Johns | 1 | -6998/+0 | |
2016-10-29 | shell: Fix code-block warnings. | Chris Johns | 5 | -294/+293 | |
2016-10-27 | rtems-docs: Fix many unnecessary back slashes | Joel Sherrill | 2 | -11/+11 | |
2016-10-27 | Misc: Capitalize RTEMS. | Joel Sherrill | 2 | -6/+6 | |
2016-10-27 | shell/file_and_directory.rst: Correct mkdos command. | Joel Sherrill | 1 | -1/+8 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 11 | -0/+22 | |
2016-05-02 | Update version numbers and the titles. | Chris Johns | 1 | -3/+4 | |
2016-05-02 | Update the shell user's guide top level. | Chris Johns | 1 | -10/+14 | |
2016-05-02 | Add OAR copyright to each file. | Chris Johns | 6 | -1/+25 | |
2016-05-02 | Clean up. | Chris Johns | 1 | -370/+431 | |
2016-05-02 | Clean up. | Chris Johns | 1 | -229/+249 | |
2016-05-02 | Clean up the memory commands. | Chris Johns | 1 | -162/+186 | |
2016-05-02 | Add links from the command list to the commands. | Chris Johns | 2 | -47/+140 | |
2016-05-02 | Add 'waf linkcheck' to check external references. | Amar Takhar | 1 | -1/+1 | |
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 2 | -6/+5 | |
2016-05-02 | Add missed conf.py. | Amar Takhar | 1 | -0/+8 | |
No idea how this happened. | |||||
2016-05-02 | Clean up of file and directory commands. | Chris Johns | 1 | -850/+866 | |
2016-05-02 | Add support for spellchecking with a custom dictionary. | Amar Takhar | 1 | -1/+1 | |
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | |||||
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 4 | -47/+47 | |
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 1 | -9/+1 | |
Needed to switch due to increasing complexity. | |||||
2016-05-02 | Clean up of general commands. | Chris Johns | 1 | -308/+319 | |
2016-05-02 | Move preface/intro one level up so the section is unnumbered. | Amar Takhar | 1 | -1/+2 | |
2016-05-02 | Clean up config and init. | Chris Johns | 1 | -26/+25 | |
2016-05-02 | Split document. | Amar Takhar | 11 | -1/+7005 | |
2016-05-02 | Clean up the alias command. | Chris Johns | 1 | -34/+33 | |
2016-05-02 | Cleaned up to General Commands. | Chris Johns | 1 | -346/+246 | |
2016-05-02 | Fix references. | Amar Takhar | 1 | -9/+3 | |
2016-05-02 | Fix broken markup. | Amar Takhar | 1 | -1/+44 | |
