* | Update version numbers and the titles. | Chris Johns | 2016-05-02 | 1 | -3/+4 |
* | Update the shell user's guide top level. | Chris Johns | 2016-05-02 | 1 | -10/+14 |
* | Add OAR copyright to each file. | Chris Johns | 2016-05-02 | 6 | -1/+25 |
* | Clean up. | Chris Johns | 2016-05-02 | 1 | -370/+431 |
* | Clean up. | Chris Johns | 2016-05-02 | 1 | -229/+249 |
* | Clean up the memory commands. | Chris Johns | 2016-05-02 | 1 | -162/+186 |
* | Add links from the command list to the commands. | Chris Johns | 2016-05-02 | 2 | -47/+140 |
* | Add 'waf linkcheck' to check external references. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 2 | -6/+5 |
* | Add missed conf.py. | Amar Takhar | 2016-05-02 | 1 | -0/+8 |
| | | | | No idea how this happened. | ||||
* | Clean up of file and directory commands. | Chris Johns | 2016-05-02 | 1 | -850/+866 |
* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | ||||
* | Convert all Unicode to ASCII(128) | Amar Takhar | 2016-05-02 | 4 | -47/+47 |
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 1 | -9/+1 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Clean up of general commands. | Chris Johns | 2016-05-02 | 1 | -308/+319 |
* | Move preface/intro one level up so the section is unnumbered. | Amar Takhar | 2016-05-02 | 1 | -1/+2 |
* | Clean up config and init. | Chris Johns | 2016-05-02 | 1 | -26/+25 |
* | Split document. | Amar Takhar | 2016-05-02 | 11 | -1/+7005 |
* | Clean up the alias command. | Chris Johns | 2016-05-02 | 1 | -34/+33 |
* | Cleaned up to General Commands. | Chris Johns | 2016-05-02 | 1 | -346/+246 |
* | Fix references. | Amar Takhar | 2016-05-02 | 1 | -9/+3 |
* | Fix broken markup. | Amar Takhar | 2016-05-02 | 1 | -1/+44 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 3 | -0/+7080 |
