path: root/shell/preface.rst (follow)
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-111-1/+0
* Use standard format for copyright linesSebastian Huber2019-01-111-2/+1
* shell: Fix header levels.Chris Johns2016-11-091-3/+1
* Set SPDX License Identifier in each source file.Chris Johns2016-05-201-0/+2
* Add OAR copyright to each file.Chris Johns2016-05-021-1/+5
* Convert all Unicode to ASCII(128)Amar Takhar2016-05-021-3/+3
* Move preface/intro one level up so the section is unnumbered.Amar Takhar2016-05-021-1/+2
* Split document.Amar Takhar2016-05-021-0/+113
