2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -2/+1 | |
2016-11-09 | shell: Fix header levels. | Chris Johns | 1 | -1/+1 | |
2016-11-08 | shell: Update commands to use descriptions. | Chris Johns | 1 | -388/+368 | |
2016-10-29 | shell: Fix code-block warnings. | Chris Johns | 1 | -28/+28 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Clean up the memory commands. | Chris Johns | 1 | -162/+186 | |
2016-05-02 | Split document. | Amar Takhar | 1 | -0/+613 | |
