2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2019-03-21 | shell/dl: Add dynamic loader commands | Chris Johns | 1 | -1/+2 | |
2019-02-28 | Add unicode support for commonly used characters like copyright. | Chris Johns | 1 | -4/+6 | |
- This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | |||||
2019-02-15 | Use pathto() on the genindex URL to make it relative. | Chris Johns | 1 | -2/+0 | |
2019-01-14 | Reformat and update copyright and license notices | Sebastian Huber | 1 | -8/+8 | |
For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -2/+1 | |
2019-01-09 | Add common header.rst to reduce copy and paste | Sebastian Huber | 1 | -23/+1 | |
2018-10-19 | Update the copyright year. | Chris Johns | 1 | -1/+1 | |
2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 1 | -1/+1 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2017-11-12 | Add indexes to all documents. | Chris Johns | 1 | -2/+1 | |
Update #3229. | |||||
2017-08-11 | Update copyright notices. | Chris Johns | 1 | -5/+8 | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | 1 | -5/+5 | |
2016-11-08 | shell: Update commands to use descriptions. | Chris Johns | 1 | -1/+1 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Update the shell user's guide top level. | Chris Johns | 1 | -10/+14 | |
2016-05-02 | Add OAR copyright to each file. | Chris Johns | 1 | -0/+4 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -2/+2 | |
2016-05-02 | Split document. | Amar Takhar | 1 | -1/+46 | |
