path: root/shell/index.rst (follow)
* shell/dl: Add dynamic loader commandsChris Johns2019-03-211-1/+2
* Add unicode support for commonly used characters like copyright.Chris Johns2019-02-281-4/+6
| | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals.
* Use pathto() on the genindex URL to make it relative.Chris Johns2019-02-151-2/+0
* Reformat and update copyright and license noticesSebastian Huber2019-01-141-8/+8
| | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-111-1/+0
* Use standard format for copyright linesSebastian Huber2019-01-111-2/+1
* Add common header.rst to reduce copy and pasteSebastian Huber2019-01-091-23/+1
* Update the copyright year.Chris Johns2018-10-191-1/+1
* build: Fix indexing so it works on HTML and PDF.Chris Johns2018-08-211-1/+1
| | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
* Add indexes to all documents.Chris Johns2017-11-121-2/+1
| | | | Update #3229.
* Update copyright notices.Chris Johns2017-08-111-5/+8
* Update document titles for consistencyJoel Sherrill2017-01-111-5/+5
* shell: Update commands to use descriptions.Chris Johns2016-11-081-1/+1
* Set SPDX License Identifier in each source file.Chris Johns2016-05-201-0/+2
* Update the shell user's guide top level.Chris Johns2016-05-021-10/+14
* Add OAR copyright to each file.Chris Johns2016-05-021-0/+4
* Convert all Unicode to ASCII(128)Amar Takhar2016-05-021-2/+2
* Split document.Amar Takhar2016-05-021-1/+46
* Initial reST documentation using Sphinx.Amar Takhar2016-05-021-0/+1
