index
rtems-docs
4.11
5
master
RTEMS Project documentation.
devel@rtems.org
summary
refs
log
tree
commit
diff
stats
log msg
author
committer
range
path:
root
shell
file_and_directory.rst
follow
Commit message (
Collapse
Author
Age
Lines
Simplify SPDX-License-Identifier comment
Sebastian Huber
2019-01-11
1
-1
+1
Remove superfluous "All rights reserved."
Sebastian Huber
2019-01-11
1
-1
+0
Use standard format for copyright lines
Sebastian Huber
2019-01-11
1
-2
+1
shell: Fix header levels.
Chris Johns
2016-11-09
1
-3
+3
shell: Update commands to use descriptions.
Chris Johns
2016-11-08
1
-1872
+1805
shell: Fix code-block warnings.
Chris Johns
2016-10-29
1
-111
+111
rtems-docs: Fix many unnecessary back slashes
Joel Sherrill
2016-10-27
1
-1
+1
shell/file_and_directory.rst: Correct mkdos command.
Joel Sherrill
2016-10-27
1
-1
+8
Set SPDX License Identifier in each source file.
Chris Johns
2016-05-20
1
-0
+2
Add OAR copyright to each file.
Chris Johns
2016-05-02
1
-0
+4
Add links from the command list to the commands.
Chris Johns
2016-05-02
1
-29
+82
Clean up of file and directory commands.
Chris Johns
2016-05-02
1
-850
+866
Convert all Unicode to ASCII(128)
Amar Takhar
2016-05-02
1
-31
+31
Split document.
Amar Takhar
2016-05-02
1
-0
+2656
