2017-03-27 | waf: Cleaner formatting to see the importing. | Chris Johns | 1 | -12/+7 | |
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -5/+5 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 3 | -0/+6 | |
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 1 | -0/+4 | |
2016-05-02 | Add support for spellchecking with a custom dictionary. | Amar Takhar | 1 | -1/+1 | |
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | |||||
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 2 | -21/+12 | |
Needed to switch due to increasing complexity. | |||||
2016-05-02 | Fix rtemsconfig building. | Amar Takhar | 1 | -0/+14 | |
I'll probably move to a more pythonic way of doing conf.py since this is getting too complicated. |
