* | Use pathto() on the genindex URL to make it relative. | Chris Johns | 2019-02-15 | 1 | -5/+0 |
* | waf: Remove as many sys path hacks as we can. | Chris Johns | 2019-02-13 | 1 | -11/+7 |
| | | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance. | ||||
* | build: Prepend project common path | Sebastian Huber | 2019-02-08 | 2 | -2/+2 |
| | | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library). | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 3 | -3/+3 |
* | waf: Cleaner formatting to see the importing. | Chris Johns | 2017-03-27 | 1 | -12/+7 |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -5/+5 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 3 | -0/+6 |
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 1 | -0/+4 |
* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | ||||
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 2 | -21/+12 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Fix rtemsconfig building. | Amar Takhar | 2016-05-02 | 1 | -0/+14 |
| | | | | | I'll probably move to a more pythonic way of doing conf.py since this is getting too complicated. | ||||
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 4 | -0/+72 |
