* | rsb: Reword some sentences | Chris Johns | 2019-01-11 | 1 | -6/+6 |
* | rsb: Move content of duplicate section | Sebastian Huber | 2019-01-11 | 4 | -66/+24 |
| | | | | | Move "Controlling the Tools Build" section and "Building Tools and RTEMS" chapter to "Project Sets" chapter and "RTEMS" section. | ||||
* | rsb: Move "Why Build from Source?" to own chapter | Sebastian Huber | 2019-01-11 | 3 | -56/+60 |
* | rsb: Move "History" to own chapter | Sebastian Huber | 2019-01-11 | 3 | -33/+38 |
| | | | | Move it to the end of the document. It is auxiliary information. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 9 | -9/+9 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 8 | -16/+8 |
* | rsb: Fix chapter layout | Sebastian Huber | 2019-01-09 | 1 | -3/+0 |
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | Move duplicate host configuration information from RSB to Users Guide | Joel Sherrill | 2018-10-13 | 2 | -348/+0 |
* | Merge duplicative RSB Quick Start into Users Guide | Joel Sherrill | 2018-10-13 | 4 | -540/+72 |
* | rsb/hosts.rst: Add more packages needed on Ubuntu | Joel Sherrill | 2018-09-25 | 1 | -2/+2 |
| | | | | Closes #3517. | ||||
* | RSB: Fix MacOS typos | Joel Sherrill | 2018-09-25 | 1 | -3/+3 |
| | | | | Close #3518. | ||||
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 2 | -5/+1 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | rsb: Add '--patchdir' option description | Maksim E. Kozlov | 2018-03-26 | 1 | -0/+7 |
| | | | | | | | According to commit d30be3129e9681a74efc80ce241aaf3c3a5b0efe in rtems-source-builder repo. Signed-off-by: Maksim E. Kozlov <maksim.e.kozlov@gmail.com> | ||||
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 2 | -2/+5 |
| | | | | Update #3229. | ||||
* | Add PAX to the Ubuntu packages to install. | Chris Johns | 2017-09-04 | 1 | -1/+1 |
| | | | | Closes #3008. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -2/+8 |
* | docs/rsb/configuration.rst: Fix typos, grammar. | Cillian O'Donnell | 2017-06-14 | 1 | -28/+28 |
* | rsb: Mention Ada language option | Sebastian Huber | 2017-06-06 | 1 | -3/+6 |
* | hosts.rst: Correct Ubuntu instructions | Linda Huxley | 2017-04-25 | 1 | -2/+2 |
| | | | | closes #3005. | ||||
* | waf: Cleaner formatting to see the importing. | Chris Johns | 2017-03-27 | 1 | -2/+7 |
* | rsb: Fix the path to the tar for the untar with strip option. | Chris Johns | 2017-03-21 | 1 | -5/+6 |
| | | | | | | | The change is different to the ticket because the example is about coping and deploying the build on a different machine. Closes #2324. | ||||
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -4/+5 |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 2 | -4/+4 |
* | Remove references to SPARC/SIS BSP. Also clean up old ERC32 references. | Joel Sherrill | 2017-01-11 | 1 | -1/+1 |
| | | | | updates #2810. | ||||
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -2/+2 |
* | RSB: Fix the history. | Chris Johns | 2016-11-02 | 2 | -33/+9 |
* | RSB: Fix the heading level for the PDF. | Chris Johns | 2016-11-02 | 10 | -100/+112 |
* | RSB: Finish reformatting after moving from asciidocs. | Chris Johns | 2016-11-02 | 11 | -3504/+3534 |
* | rsb: Fix the tex name. | Chris Johns | 2016-10-31 | 1 | -1/+1 |
* | RSB: Clean up formatting and fix code-block mistakes. | Joel Sherrill | 2016-10-30 | 1 | -156/+173 |
* | RSB: Make the bullet style more consistent. | Joel Sherrill | 2016-10-30 | 2 | -34/+43 |
* | RSB: Initial addition | Joel Sherrill | 2016-10-30 | 4 | -0/+3620 |
The content was manually converted from Asciidoc to Sphinx and there are some areas which remain to be done. Specifically there are some tables and embedded links which are known to remain but there are almost certainly other things to clean up. |
