2017-01-11 | Update document titles for consistency | Joel Sherrill | 2 | -4/+4 | |
2017-01-11 | Remove references to SPARC/SIS BSP. Also clean up old ERC32 references. | Joel Sherrill | 1 | -1/+1 | |
updates #2810. | |||||
2016-12-21 | Update version/revision to 4.11.99 | Sebastian Huber | 1 | -2/+2 | |
2016-11-02 | RSB: Fix the history. | Chris Johns | 2 | -33/+9 | |
2016-11-02 | RSB: Fix the heading level for the PDF. | Chris Johns | 10 | -100/+112 | |
2016-11-02 | RSB: Finish reformatting after moving from asciidocs. | Chris Johns | 11 | -3504/+3534 | |
2016-10-31 | rsb: Fix the tex name. | Chris Johns | 1 | -1/+1 | |
2016-10-30 | RSB: Clean up formatting and fix code-block mistakes. | Joel Sherrill | 1 | -156/+173 | |
2016-10-30 | RSB: Make the bullet style more consistent. | Joel Sherrill | 2 | -34/+43 | |
2016-10-30 | RSB: Initial addition | Joel Sherrill | 4 | -0/+3620 | |
The content was manually converted from Asciidoc to Sphinx and there are some areas which remain to be done. Specifically there are some tables and embedded links which are known to remain but there are almost certainly other things to clean up. |
