2019-01-14 | user: Add RSB content as a chapter | Sebastian Huber | 1 | -14/+0 | |
Remove the separate RSB manual. | |||||
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -4/+5 | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | 1 | -1/+1 | |
2016-12-21 | Update version/revision to 4.11.99 | Sebastian Huber | 1 | -2/+2 | |
2016-10-31 | rsb: Fix the tex name. | Chris Johns | 1 | -1/+1 | |
2016-10-30 | RSB: Make the bullet style more consistent. | Joel Sherrill | 1 | -2/+2 | |
2016-10-30 | RSB: Initial addition | Joel Sherrill | 1 | -0/+0 | |
The content was manually converted from Asciidoc to Sphinx and there are some areas which remain to be done. Specifically there are some tables and embedded links which are known to remain but there are almost certainly other things to clean up. | |||||
2016-05-02 | Update version numbers and the titles. | Chris Johns | 1 | -3/+4 | |
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 1 | -0/+12 | |
