path: root/posix1003_1 (unfollow)
2016-05-20Set SPDX License Identifier in each source file.Chris Johns23-0/+46
2016-05-02Add 'waf linkcheck' to check external references.Amar Takhar1-1/+1
2016-05-02Add PDF generation support use with --pdfAmar Takhar2-6/+5
2016-05-02Add support for spellchecking with a custom dictionary.Amar Takhar1-1/+1
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar.
2016-05-02Convert all Unicode to ASCII(128)Amar Takhar5-24/+24
2016-05-02Rework how conf.py is handled.Amar Takhar2-9/+9
Needed to switch due to increasing complexity.
2016-05-02Split document into seperate files by section.Amar Takhar22-1/+3609
2016-05-02Fix warnings.Amar Takhar1-12/+4
