path: root/posix-users (unfollow)
2020-01-24posix-users/message_passing.rst: Add status for cannot block in ISRJoel Sherrill1-0/+2
Updates #3857.
2019-09-03Address several issues from compiling examplesMartin Erik Werner2-13/+5
Compiling the code from examples "code-block:: c" along with public includes and a bsp exposed a few issues amongst a lot of false positives. Address some of these: * Terminate struct declarations with ';'. Mainly for pedantic correctness. * Show ptrdiff_t instead of size_t for the sbrk() prototype, matching the current argument type in rtems. * Replace some occurrences of unsigned16 with uint16_t. * Fix odd type declaration, "uint8_t char*" -> "char*". * Use appropriate helper to get chain head instead of invalid access to nonexistent struct member. * Remove several excess '\' escapes. * Use RTEMS_SELF instead of undefined SELF. * Use rtems_task instead of void for task functions. * Add missing stack size parameter in task creation. * Use rtems_interrupt_level instead of undefined rtems_interrupt. * Correct return value format for rtems_object_id_get_api() rtems_object_id_get_index() (enum and uint16_t) and also fix corresponding print formatting. * Correct return value documentation for rtems_object_id_get_class(), rtems_object_id_get_node() and rtems_object_id_get_index() int -> uint32_t. * Use RTEMS_SUCCESSFUL instead of undefined RTEMS_STATUS_SUCCESSFUL and fix return value variable name in rate monotonic examples. * Use RTEMS_TIMEOUT instead of undefined TIMEOUT and RTEMS_PERIOD_STATUS instead of undefined STATUS. * Add missing fields to ftpd configuration. * Correct parameter types in ftpd hook prototype, unsigned char * -> void *. * Fix various code-block:: attributes, c -> makefile and c -> shell. * Add missing parenthesis in socket buffer memory calculation example. * Remove typedef in declaration of mq_attr since it is defiend without typedef in reality. * Update siginfo_t declaration to match current reality. * Update shell user command definition example to include mode, uid and gid.
2019-02-28Add unicode support for commonly used characters like copyright.Chris Johns1-3/+5
- This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals.
2019-02-15Use pathto() on the genindex URL to make it relative.Chris Johns1-2/+0
2019-02-13waf: Remove as many sys path hacks as we can.Chris Johns1-11/+7
There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance.
2019-02-08build: Prepend project common pathSebastian Huber2-2/+2
This avoids conflicts with standard packages such as PIL (Python Imaging Library).
2019-01-14Reformat and update copyright and license noticesSebastian Huber1-8/+7
For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete.
2019-01-11Simplify SPDX-License-Identifier commentSebastian Huber26-26/+26
2019-01-11Remove superfluous "All rights reserved."Sebastian Huber22-22/+0
2019-01-11Use standard format for copyright linesSebastian Huber22-49/+24
2019-01-09Add common header.rst to reduce copy and pasteSebastian Huber1-23/+1
2018-11-21posix-users/input_and_output.rst: Document errors for mount() and unmount()Joel Sherrill1-4/+15
2018-11-21posix-users/device_and_class_specific.rst: Add PrototypesMarçal Comajoan Cara1-20/+28
Add and update Device and Class Specific APIs in POSIX Users Guide. This work was part of GCI 2018.
2018-11-21posix-users/input_and_output.rst: Add PrototypesMarçal Comajoan Cara1-28/+56
Add and update Prototypes to Input and Output APIs in POSIX Users Guide. This work was part of GCI 2018.
2018-11-21posix-users/memory_managment.rst: Add PrototypesMarçal Comajoan Cara1-0/+22
Add Prototypes to Memory Management APIs in POSIX Users Guide. This work was part of GCI 2018.
2018-11-21posix-users/system_database.rst: Add PrototypesMarçal Comajoan Cara1-4/+36
Add Prototypes to System Database APIs in POSIX Users Guide. This work was part of GCI 2018.
2018-11-21posix-users/thread_cancellation.rst: Add PrototypesMarçal Comajoan Cara1-3/+18
Add Prototypes to Thread Cancellation APIs. This work was part of GCI 2018.
2018-11-21posix-users/language_specific_services.rst: Add Prototypes to Language ↵Marçal Comajoan Cara1-42/+48
Specific Service APIs This work was part of GCI 2018.
2018-10-19Update the copyright year.Chris Johns1-1/+1
2018-08-21build: Fix indexing so it works on HTML and PDF.Chris Johns2-5/+1
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
2017-11-12Add indexes to all documents.Chris Johns2-2/+5
Update #3229.
2017-10-24posix-users: Clarify timed operation errorsSebastian Huber2-3/+7
Close #3182.
2017-10-11posix-users/thread.rst: Add pthread_getconcurrency and pthread_setconcurrencyJoel Sherrill1-0/+69
Closes #2680.
2017-08-11Update copyright notices.Chris Johns1-4/+7
2017-07-28memory_management: update mmap, munmap, shm_open, shm_unlinkGedare Bloom1-9/+140
Close #2859.
2017-07-28posix1003-1, posix_users: mark mmap and shm functions implementedGedare Bloom1-2/+1
Update #2859.
2017-04-25POSIX Users: Add posix_devctl()Joel Sherrill2-0/+76
2017-03-27waf: Cleaner formatting to see the importing.Chris Johns1-2/+7
2017-03-20Use a single top level version number.Chris Johns1-4/+5
2017-01-11Update document titles for consistencyJoel Sherrill2-7/+7
2016-12-21Update version/revision to 4.11.99Sebastian Huber1-2/+2
2016-11-03Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns27-0/+12452
