* | Use pathto() on the genindex URL to make it relative. | Chris Johns | 2019-02-15 | 1 | -2/+0 |
* | waf: Remove as many sys path hacks as we can. | Chris Johns | 2019-02-13 | 1 | -11/+7 |
| | | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance. | ||||
* | build: Prepend project common path | Sebastian Huber | 2019-02-08 | 2 | -2/+2 |
| | | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library). | ||||
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 1 | -8/+7 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 26 | -26/+26 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 22 | -22/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 22 | -49/+24 |
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | posix-users/input_and_output.rst: Document errors for mount() and unmount() | Joel Sherrill | 2018-11-21 | 1 | -4/+15 |
* | posix-users/device_and_class_specific.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -20/+28 |
| | | | | | | | Add and update Device and Class Specific APIs in POSIX Users Guide. This work was part of GCI 2018. | ||||
* | posix-users/input_and_output.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -28/+56 |
| | | | | | | | Add and update Prototypes to Input and Output APIs in POSIX Users Guide. This work was part of GCI 2018. | ||||
* | posix-users/memory_managment.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -0/+22 |
| | | | | | | Add Prototypes to Memory Management APIs in POSIX Users Guide. This work was part of GCI 2018. | ||||
* | posix-users/system_database.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -4/+36 |
| | | | | | | Add Prototypes to System Database APIs in POSIX Users Guide. This work was part of GCI 2018. | ||||
* | posix-users/thread_cancellation.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -3/+18 |
| | | | | | | Add Prototypes to Thread Cancellation APIs. This work was part of GCI 2018. | ||||
* | posix-users/language_specific_services.rst: Add Prototypes to Language ↵ | Marçal Comajoan Cara | 2018-11-21 | 1 | -42/+48 |
| | | | | | | Specific Service APIs This work was part of GCI 2018. | ||||
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 2 | -5/+1 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 2 | -2/+5 |
| | | | | Update #3229. | ||||
* | posix-users: Clarify timed operation errors | Sebastian Huber | 2017-10-24 | 2 | -3/+7 |
| | | | | Close #3182. | ||||
* | posix-users/thread.rst: Add pthread_getconcurrency and pthread_setconcurrency | Joel Sherrill | 2017-10-11 | 1 | -0/+69 |
| | | | | Closes #2680. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -4/+7 |
* | memory_management: update mmap, munmap, shm_open, shm_unlink | Gedare Bloom | 2017-07-28 | 1 | -9/+140 |
| | | | | Close #2859. | ||||
* | posix1003-1, posix_users: mark mmap and shm functions implemented | Gedare Bloom | 2017-07-28 | 1 | -2/+1 |
| | | | | Update #2859. | ||||
* | POSIX Users: Add posix_devctl() | Joel Sherrill | 2017-04-25 | 2 | -0/+76 |
* | waf: Cleaner formatting to see the importing. | Chris Johns | 2017-03-27 | 1 | -2/+7 |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -4/+5 |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 2 | -7/+7 |
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -2/+2 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 27 | -0/+12452 |
