2018-11-21 | posix-users/input_and_output.rst: Document errors for mount() and unmount() | Joel Sherrill | 1 | -4/+15 | |
2018-11-21 | posix-users/device_and_class_specific.rst: Add Prototypes | Marçal Comajoan Cara | 1 | -20/+28 | |
Add and update Device and Class Specific APIs in POSIX Users Guide. This work was part of GCI 2018. | |||||
2018-11-21 | posix-users/input_and_output.rst: Add Prototypes | Marçal Comajoan Cara | 1 | -28/+56 | |
Add and update Prototypes to Input and Output APIs in POSIX Users Guide. This work was part of GCI 2018. | |||||
2018-11-21 | posix-users/memory_managment.rst: Add Prototypes | Marçal Comajoan Cara | 1 | -0/+22 | |
Add Prototypes to Memory Management APIs in POSIX Users Guide. This work was part of GCI 2018. | |||||
2018-11-21 | posix-users/system_database.rst: Add Prototypes | Marçal Comajoan Cara | 1 | -4/+36 | |
Add Prototypes to System Database APIs in POSIX Users Guide. This work was part of GCI 2018. | |||||
2018-11-21 | posix-users/thread_cancellation.rst: Add Prototypes | Marçal Comajoan Cara | 1 | -3/+18 | |
Add Prototypes to Thread Cancellation APIs. This work was part of GCI 2018. | |||||
2018-11-21 | posix-users/language_specific_services.rst: Add Prototypes to Language ↵ | Marçal Comajoan Cara | 1 | -42/+48 | |
Specific Service APIs This work was part of GCI 2018. | |||||
2018-10-19 | Update the copyright year. | Chris Johns | 1 | -1/+1 | |
2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2 | -5/+1 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2017-11-12 | Add indexes to all documents. | Chris Johns | 2 | -2/+5 | |
Update #3229. | |||||
2017-10-24 | posix-users: Clarify timed operation errors | Sebastian Huber | 2 | -3/+7 | |
Close #3182. | |||||
2017-10-11 | posix-users/thread.rst: Add pthread_getconcurrency and pthread_setconcurrency | Joel Sherrill | 1 | -0/+69 | |
Closes #2680. | |||||
2017-08-11 | Update copyright notices. | Chris Johns | 1 | -4/+7 | |
2017-07-28 | memory_management: update mmap, munmap, shm_open, shm_unlink | Gedare Bloom | 1 | -9/+140 | |
Close #2859. | |||||
2017-07-28 | posix1003-1, posix_users: mark mmap and shm functions implemented | Gedare Bloom | 1 | -2/+1 | |
Update #2859. | |||||
2017-04-25 | POSIX Users: Add posix_devctl() | Joel Sherrill | 2 | -0/+76 | |
2017-03-27 | waf: Cleaner formatting to see the importing. | Chris Johns | 1 | -2/+7 | |
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -4/+5 | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | 2 | -7/+7 | |
2016-12-21 | Update version/revision to 4.11.99 | Sebastian Huber | 1 | -2/+2 | |
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 27 | -0/+12452 | |
