2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -2/+1 | |
2018-11-21 | posix-users/memory_managment.rst: Add Prototypes | Marçal Comajoan Cara | 1 | -0/+22 | |
Add Prototypes to Memory Management APIs in POSIX Users Guide. This work was part of GCI 2018. | |||||
2017-07-28 | memory_management: update mmap, munmap, shm_open, shm_unlink | Gedare Bloom | 1 | -9/+140 | |
Close #2859. | |||||
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | POSIX User clean up. | Chris Johns | 1 | -51/+97 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -2/+2 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+265 | |
